cameleonrouge00157702de
- Dec 4, 2021
Hello
I have a problem with my computer. I have the impression that it gets too hot so it turns off and then starts again without a blue screen.
When I play Forza Horizon 5 or recent games it easily reaches 100 ° C / 212 °F ( CPU ) and cuts out around every 1 hour of games which poses a problem. I have the impression that my computer bears its name very badly and that it becomes a volcano instead of an Artic ^^
This did not happen at first, and for information I have had the computer for less than 2 years.
Solution tried :
- I have tried many methods including increasing the ventilation of the FAN in the bios, to be honest I put it to full force so my computer is more of a factory than something silent.
- lower the game parameters (which is annoying when you have a gaming computer)
I ask you for help and what advice you can give me before I send it for repair. Because it becomes unplayable.
I thank you in advance for your response
my config :
OS : WINDOWS 11 FAMILLY
Processeur Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz 3.00 GHz
Mémoire RAM 16,0 Go
Type du système Système d’exploitation 64 bits, processeur x64
CGU : Nvdia Geforce GTX 1660 SUPER
Solution tried :
my config :
Mémoire RAM 16,0 Go
