Msi vector 16 charger issue
balazs.navreczki
My MSI Vector HX AI A2XWHG is only 3 weeks old. The charging connector/cable on the laptop side feels a little loose and makes a squeaking noise when I move it. However, charging is completely stable and doesn't disconnect, even when I move the plug around.
Has anyone else noticed this? Is it considered normal, or should I be concerned? Would you recommend a warranty replacement? Thank you for your help.
From the picture, it looks like the adhesive is loose. If charging is normal, you can continue using it, or you can contact MSI customer service for assistance.
