MSI Vector 16HX AI audio failure, Help!
i used first their own drivers then updated to the most recent.
i have since uninstalled and tried just their own drivers, even the one named "amd graphics driver" 1127367_Win10_x64(566.36)_Studio_32.0.15.6636_0x8ff1fefd but that also did not install the audio coprocessor drivers. tried uninstalling everything and installing that a couple of times now, it does nothing.
This seems like a totally different issue with this topic.
Refer to the FAQ to update BIOS and clean install the AMD graphics driver for your laptop.
https://www.msi.com/faq/faq-11246
I'm again with audio crackling on both realtek and external iFi Zen Dac V2. If you have any solution that works it will be appreciated..
What version of audio drivers are installed on your laptop? Intel smart sound, Realtek audio driver, Nahimic, and IntelliGo driver.
It doesn't really matter. I was on official drivers from MSI with a clean Windows 11 installation - crackling. Now with all the latest versions available over the internet from SDI, and still sound crackling. What is very STRANGE the same device - external sound card - iFi Zen Dac V2 is crackling with this laptop - with the others does not sic!
The external sound card - iFi Zen Dac V2, is it connected to the USB A or C port or the 3.5mm audio port? Would the other external USB devices be disconnected at the same time?
I'm guessing that the PCH might be overheated.
Still having the crackling sound with the laptop speaker and audiodg.exe error?
Yes, connected audio devices are irrelevant. This error also happens when no headphones or external speakers are connected to the device. .
And it's definitely not related to background tasks or heat. Actually, in my case it usually happens when I'm simply browsing the web (or doing other very light tasks).
So many people face this issue and many tickets have been opened to MSI support.. Is it still unclear? It is freaking obvious. MSI realtek drivers are not fully compatible with the newest win 11 25h2 version. They need to be updated from MSI.
I don't know if a bios update can fix this.. I have updated it 2 times, but problem remains unchanged.
No matter if I plug it via USB A or C - problem exists...
I'm so dissapointed at this moment with all the audio troubles I have using this laptop...
I've been having audio issues since I bought my MSI Vector 16 HX AI laptop. Audio fails completely and no sites with audio work, or gets buzzing, crackling noises. I've contacted MSI multiple times and they have no idea what it is. They only say update BIOS or give you an outdated Windows 10 document that says uninstall all drivers and reinstall from their website, and don't update drivers again from windows or any third party platforms, which is a ridiculous solution. Nevertheless, didn't work. Sounds like the attached https://drive.google.com/file/d/1gS6xu0GV6Dz8WD5SOU5wIb3VBTsQ7-HJ/view?usp=drive_link
I have MSI Vector A2XWHG and i have same problem with you guys, and i trying to change the sound driver to windows driver and now its works
-Press Windows + X → select Device Manager
-Open Sound, video and game controllers
-Find Realtek(R) Audio, Realtek High Definition Audio, or similar → right-click → Update driver
-Select Browse my computer for drivers
-Then select Let me pick from a list of available drivers on my computer
-Uncheck Show compatible hardware (important!)
-In the left column, select Microsoft as the manufacturer
-In the right column, select High Definition Audio Device (usually the newest/top one)
-Click Next → install → restart PC
Then i disable nahimic driver too from Device Manager
hope it's works on you too :)
read my
please read this
did you solve it by doing this?
read my
please read this
Unfortunately didn't work for me.. Going to install linux until this is fixed..
#Technical Details
Description
Faulting application name: AUDIODG.EXE, version: 10.0.26100.7920, time stamp: 0x02584316
Faulting module name: ntdll.dll, version: 10.0.26100.7920, time stamp: 0x5ffc11eb
Exception code: 0xc0000374
Fault offset: 0x00000000001176e5
Faulting process id: 0xB98
Faulting application start time: 0x1DCB08E87FDA054
Faulting application path: C:\WINDOWS\system32\AUDIODG.EXE
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: ef99a2e8-64be-441a-a847-d72ab15354a3
Faulting package full name:
Faulting package-relative application ID:
i purposely login to reply this works for me. genius
Audio keeps failing randomly, this has been happening for 3 weeks and i had the device for about 2 month, i tried the following:
1- Removed shitty Nahimic app and drivers
2- disabled audio enhancements
3- did an EC reset.
4- updated all graphics and audio drivers
5- rolled back drivers after uodate as issue persisted and installed manually through MSI website, same issue happens.
6- tested external speakers and headphones, issue doesn't happen, only with built-in speakers
7- Always gets fixed with a restart, but if i dont this buzzing sound does't go away even if i disable realtek speakers but laptop keeps working fine.
I would be very grateful if anyone can help me here as the only option i can see left is to send for a service
It's your pch chip bro. I found the solution... Vector 16 HX AI usb disconnecting solved
MSI Vector 16 HX AI A2XW USB disconnecting during use Solution, PCH Overheating Fixed 🛠️
When experiencing audio crackling, stuttering, or distorted sound while playing videos, music, or during calls, follow the troubleshooting steps below:
Update Nahimic APO to version 5.0.6
Audio crackling is often linked to an outdated Nahimic Audio Processing Object (APO) driver. Install the latest version:
That does not help. I have this latest nahimic and still sound is crackling from time to time and my camera behave strange at the same time...
Totally feel your pain, man. At this point, your best bet is to just take it to a local MSI service center and demand a full hardware diagnostic or a motherboard swap.
Hopefully they can get it sorted out for you.
