MSI Ventus 2080 Ti Temperature issue
Den777
Hello MSI team,
I have a MSI Ventus 2080 Ti (non OC) and in various 3D games or MSI Kombustor, the GPU temp rises to 83°C and the fans rev up to 4100-4200 rpm for 5 seconds then down again, then back up and down plenty of times, even with an open case.
I noticed that, when running these programs, if I exert a pressure with my hand on the center of the 2080 (between the two fans), so as to press the radiator against the GPU a bit more, the temperature immediately goes down 4-5 degrees celsius, and the fan noise becomes acceptable again (no fan revving). When I release the pressure it goes back up to about 82-84°C after a few seconds.
Update : I don't use a support stick (unless I'm wrong, there was none in the box with the card).
When the PC is horizontal and I let the card sits vertically, the same problem happens, the fans revs up and down regularly (ranging from about 2500 to 4200 rpm) and the card reaches 83°C under full load. That's with no pressure from my hand.
Following Svet suggestion, I ran MSI Kombustor and tried to push/support the card from under the side of the power connectors, with the PC back to it's vertical position : the card immediately loses 5 to 6°C under load (down to 77-78°C) and there's no fan revving then. When I stop the pressure with my hand it quickly goes back up to about 83°C under the same load and the regular fan revving comes back.
Do you think my card has bending/sagging ? Should I RMA ?
SN : 602-V371-55SB1901001226
vBIOS :
PG150 SKU 31 VGA BIOS
MSINV371MH.210
My PC
CPU : i9-9900K
MB : Aorus Z390 (Bios F6)
RAM : 64 Gb Ballistix Tactical BLT4C16G4D30AETA DDR4-3000
PSU : Corsair RM1000x
Thank you.
Den777
Hello MSI team,
I have a MSI Ventus 2080 Ti (non OC) and in various 3D games or MSI Kombustor, the GPU temp rises to more than 82°C and FAN 1 revs up to 4100-4200 rpm for 5 seconds then revs down again, then back up and down plenty of times, even with an open case.
vBIOS :
MSINV371MH.210
My PC
CPU : i9-9900K
Thank you.
Administrator
Do you use the support stick?
Have you tried to push/support the card with hand from the right corner and retest?
or to place the PC case horizontally, and let the card sit vertically and retest
Den777
Following your suggestion, I ran MSI Kombustor and tried to push/support the card from under the side of the power connectors, with the PC back to it's vertical position : the card immediately loses 5 to 6°C under load (down to 77-78°C) and there's no fan revving then. When I stop the pressure with my hand it quickly goes back up to about 83°C under the same load and the regular fan revving comes back.
What would you recommend ?
Administrator
Yep, appear this model doesn't come with such.
RMA the card
