MSI Ventus GeForce RTX 4070 SUPER - Afterburner Voltage not working.
Atticus182
The card seems to be working fine. For the life of me, I can't get the Voltage to show up in MSI afterburner like it did with my MSI 3060 card. I've reinstalled the drivers, reinstalled afterburner, gone back to my old card (which shows the voltage), then back to the new one. Nada. What can I do to fix this?
Thanks in advance!
Try press CTRL+F
Thanks for the response. I am actually talking about the live voltage reporting, where it shows 0mV in the attached picture above. It usually shows in real-time the mV. I'm assuming it's because the card just came out, so afterburner needs an update for the super cards to be added?
Thanks in advance!
Check with GPU-Z
Yeah it may need update.
I also would suggest to switch and try a generic Afterburner Skin, or a different one to try who also can show the voltage.
Does the voltage is listed fine in the AB Monitor Window?
Looks like the latest MSI Afterburner beta 4.6.6 that was just released on guru 3d added the mV support for the new super cards. It works now that I've updated to the newest beta :)
