MSI X470 Gaming Pro Carbon BIOS issues
antonymagnus72
OS Name Microsoft Windows 11 Pro
Version 10.0.22000 Build 22000
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name AMAGNUS0034
System Manufacturer Micro-Star International Co., Ltd.
System Model MS-7B78
System Type x64-based PC
System SKU To be filled by O.E.M.
Processor AMD Ryzen 7 2700X Eight-Core Processor, 3700 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 2.E0, 6/10/2020
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Micro-Star International Co., Ltd.
BaseBoard Product X470 GAMING PRO CARBON (MS-7B78)
BaseBoard Version 1.0
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.22000.778"
User Name AMagnus0034\Anton
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 32.0 GB
Available Physical Memory 25.4 GB
Total Virtual Memory 37.0 GB
Available Virtual Memory 27.6 GB
Page File Space 5.00 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
So recently tried to update to the new BIOS v 7B78v2I had major problems within Windows, unexpected BSOD's and shut downs. Also when attempting to reflash the BIOS to the prior version MFLASH would not work correctly in BIOS version 7B78v2I , just a black screen.
Pro
What's your graphics card? Black screen in BIOS can easily happen with a graphics card that's older, see here. Furthermore, try the different outputs of your GPU with different cables.
antonymagnus72
Thanks for the reply! Well I do have a Nvidia 2070 Super runs wonderful under BIOS 2.E0 with secure boot enabled. I do not think the card is the issue.
I did notice a few changes in BIOS 7B78v2I that were interesting after having reinstalled it again, perusing through the settings I noticed that there were more changes than just secure boot which by the way was also enabled in BIOS 2.E0, I found that crypto mining for the graphics card was enabled in 7B78v2I which is disabled in 2.E0. I have since changed many settings to reflect what I had at 2.E0 so I am playing a wait and see game now.
Also after a bit of research someone had mentioned that MSI BIOS now requires a HDMI connection for MFLASH as opposed to a VGA or display port which may explain quite a bit if it is the case.
Pro
Yes, from a certain BIOS version onwards, "Above 4G memory / Crypto currency mining" is Enabled by default, this is also related to Resizable BAR (your card doesn't use this yet).
Let's see if you can determine an "offending setting".
