MSI x470 gaming pro won't post
cassianjvh
I built this PC about four years ago, with an x470 gaming pro, an MSI Nvidia 1060 gtx 6gb and Ryzen 7. I recently had terrible trouble when I updated to windows 11, so many things went wrong I won't detail them all, but in the end I clean installed windows 10 pro again and all seemed good once again. Until I put the PC to sleep (or so I thought) returned in the morning to find all the lights on but no monitor signal (I have 3 monitors). I tried removing the all the components (graphics card, wifi card), unplugging HDs, using only one stick of ram in each of the 4 slots. I tried ram from another computer, still nothing. I tried an alternative PSU, still nothing. I am left thinking the board must have died somehow, but not sure if there are other tests? I have fans, lights etc, but no signal to monitors. Any suggestions greatly appreciated.
Alan J T
Yes it is you Video card it has Halted on a VGA error
Do you have a spare
Can you list your full build please>>Posting Guide<<
Test GPU in a separate system if possible
cassianjvh
Thanks for getting back - I did try the graphics card in another machine and it seems to be working fine.
My build is:
Board: MSI X470 gaming pro
BIOS: Most recent / although reset trying to get it to work again
VGA: MSI Geforce GTX gaming 6gb
PSU: Corsair TX-M Series 650 Watt 80 Plus Gold Certified PSU (UK) Hybrid Modular Power Supply Unit - Black
CPU: Ryzen 7 3700x, (bought 2018 with wraith cooler)
MEM: Corsair CMK16GX4M2A2400C16R Vengeance LPX 16 GB (2 x 8 GB) DDR4 2400 MHz C16 XMP 2.0 High Performance
HDD/SSD: 1xcrucial mx500 m2 SATA sd (for OS), 1x crucial 2.5" SSD 1TB, 1XTOSHIBA 2TB HDD
COOLER: AMD Wraith prism
Keyboard: Logitech , USB
Mouse: Havit GAMING MOUSE, USB
OC: None
OS: Windows 10 64bit Professional
cassianjvh
I noticed that vga debug led is also lit if I try and start up without graphics card just plugged into the onboard HDMI ?
darkhawk
Your CPU doesn't have an integrated graphics chip built in.....so you won't get any video out, and the computer won't detect any GPU.
Do you have another computer or another GPU to test? Could you put the 1060 into another computer and see if it works fine there?
Can you try another GPU in your computer and see if it works fine?
Alan J T
Also try GPU in a different PCIE slot you seem to have enough room to move it down to second one
