zamora.omar6156902db
- Oct 18, 2022
LST, if I turn on OC Genie 4, the fan curve I have set no longer sticks. I can't tell if its static or if its a different preset curve, but it doesn't ramp up when testing with Cinebench.
Prior to turning on OC genie, I just left the CPU at default, only making changes to FCLCK for the RAM and enabling XMP. Then I have the fan curve I was talking about, which when OC genie is turned off. Totally responsive no problems. Oh also, if I set my fans to DC mode instead w/ oc genie on, they will actually ramp up on load, but then they stay at that speed even when the load is taken off.
Lets see Info:
BIOS version: 7C37vHI
CPU: Ryzen 5 3600
Mobo: MSI X570-A Pro
GPU: 6700XT PowerColor Fighter
RAM: CMW32GX4M2C3200C16 x 2
OS: Windows 10 Build 21H2
PSU 850W Seasonic
I haven't really OCd in the past, but I was using Ryzen Master seeing if I could achieve 4.2MHz on the 3600, which it can but with Ryzen Master it wont run stable with that speed without raising the voltage to about 1.45V. OC Genie 4 hits that 4.2Mhz @ 1.1V. I have yet to try manually changing the values in bios myself but I had already tried other methods to get the fan curve set w/ OC genie turned on. MSI Center recognizes its on and asks to turn off OC genie. Suggestions would be appreciated!
Lets see Info:
CPU: Ryzen 5 3600
PSU 850W Seasonic
