first one died after running update , 2nd replacement updated fine go figureIve not had a problem updating the firmware on the clutch20 but the dpi options in dragon center are pretty sparse....thats what you get for a £25 mouse i suppose.
After spending an hour tonight after work i think i have finally got things back to normal, until now i`d been trying jumping pins 4-5 with a pen nib but nothing was happening, also tried a pair of scissors...nothing, I know...try a screwdriver.....VOILLA and the firmware detected kicked in although the instructions that Msi gave didn't work...touch pins 4 and 5 quickly....more like connect pins 4 and 5 with a screwdriver for 3 seconds to kick in the firmware detection.strange my experience has been good I have SL120 unifans and set L connect to sync with motherboard using MSI Center and have no issues with syncing RGB can turn it off from mains and it keeps the profile , I pretty much control all RGB with MSI Center only thing I dont is the AIO which is Z73 and use NZXT CAM for setting curve for fans on Rad and pump also set display , I connect the PWM cable from fan to motherboard sys header , great with Lian Li as 1 cable connects 3
and use software called Fan control to create fan curves I set case fans curve according to what the GPU temp is
GitHub - Rem0o/FanControl.Releases: This is the release repository for Fan Control, a highly customizable fan controlling software for Windows.
This is the release repository for Fan Control, a highly customizable fan controlling software for Windows. - GitHub - Rem0o/FanControl.Releases: This is the release repository for Fan Control, a h...github.com
The great unify saga lol, hopefully finally over. Its a good board, the super io chip needs a lot of updates lately though, in line with windows updates...hmmmAfter spending an hour tonight after work i think i have finally got things back to normal, until now i`d been trying jumping pins 4-5 with a pen nib but nothing was happening, also tried a pair of scissors...nothing, I know...try a screwdriver.....VOILLA and the firmware detected kicked in although the instructions that Msi gave didn't work...touch pins 4 and 5 quickly....more like connect pins 4 and 5 with a screwdriver for 3 seconds to kick in the firmware detection.
If in doubt blame Microsoft.Just spent the last hour playing the division 2 with mystic lighting actually working on my Lian Li galahad 360 and my 6 sl120 fans, also the debug/temp display hasn't broken again, I`m still puzzled as to what caused the LED FW issue in the first place.
Im now running the ad2 bios and no problems but its only an Update to AGESA ComboAm4v2PI 1.2.0.7. - Change the default setting of Secure Boot which I thought they had already done in a previous bios, I updated after fixing the led fw issue and after booting my system this morning and tonight....its still working.Great newsI did the bios update today to 7C35vAD2(Beta version) mainly because of the Win11 TPM Stuttering fix
All seems to be working fine
