I just installed an MSI X58 Pro-E, along with two GTX 275 cards in SLI and a 9600GT for PhysX.
I had two issues with the install:
1) The X58 Pro-E does not come with an SLI bridge. Granted, the packaging and description don't list one, but there's no information on where to get one, either.
2) The BIOS that shipped with my Pro-E was 7.3. SLI's not enabled until 8.x. The BIOS M-Flash utility refused to recognize the 8.0, 8.1, or 8.2 BIOS files from MSI's site. It could see a copy of 7.3, though, so the utility was reading my USB stick properly. The Live Update software also reported the most up to date BIOS was 7.3, not 8.2 as listed on MSI's site. As the BIOS is 4MB, it can't be put on a floppy image and burned to CD. I had to resort to formatting my USB stick using an HP utility and then booting off that to update the BIOS.
On the upside, the board does fit an Asus Xonar DX, two GTX 275 cards, and a 9600GT (that low profile one from Galaxy). You need to put a small piece of paper over the first row of fins on the IOH HSF to prevent the first x1 PCI Express card from contacting the IOH HSF, but it doesn't need to be bent out of the way unless there are larger items on the back side of the card. Also, the Galaxy 9600GT has large screws on the back that make contact with the second GTX 275 casing, but the flexing is moderate.
Anywho, anyone know how to burn a Pro-E BIOS without resorting to a formatted USB stick? Also, are there any places to get an MSI SLI bridge? For now I'm using the one that came with an Asus P5N-D.
using the link to Tech. Support, maybe they do sell SLI bridges separately.
