This are the components of my PC:
Case: Cooler Master Stacker 832 SE incl. Zalman ZM-MFC1 Plus fancontroller and 4 fans
Processor: i7 920 Socket 1366 quad-core proc. van 2,66GHz 8MB cache
Motherboard: MSI X58 Pro-E
Memory: Corsair XMS3 CMX4GX3M2B1600C9 4GB
Graphic card: VTX3D HD ATI HD5670(HDMI, VGA, DVI)
Power Supply: Cooler Master M620 modulair
Harddisk : Samsung HD103UJ 1TB 7200rpm 32mb
Software: Windows 7 Ultimate 64 bits
I buyed this PC second hand. I have seen it working.
But when i came home it didn't, when i start the PC the PC stays on for 30 seconds everything seems to work, but i see no images on my screen and then my PC stops working and then reboot, and that happens over and over.
So i tried to reset the bios manually but that didn't seemed to work. I tried everything i know about computers. I changed the BIOS Battery, tried the CMOS button and a motherboard speaker. After a lott of testing i know it have to be 1 of this 3 parts: motherboard, processor or the ddr3 memory. I think it is the motherboard just because it makes the most sense. And now my PC restarts after 3 seconds
But In the time i tried to fix my PC, the PC gave a screen like 7 times.
The First showing a screen that said overclocking has failed.
6 others were that i could start my PC (f2) or go to BIOS (f1), i went to the bios and me screen froze or my keyboard stopped working so i could do nothing and had to restart the PC and see the same problem. This happend 3 times.
The other 3: I came to the screen and i pressed f2 and windows started like nothing happend and i could do everything i even restarted the PC and it worked also, but after that i turned off the PC for 2 hours, same problem came up.
I pressed f1 and went back to failed default settings, then the PC worked for 4 days and i could do everything with it. But after restarting my PC after four days same problem again.
I pressed f1 checked my temps and they were just fine and tried to start op windows normally but i had disconnect harddisc to conclude it out, so i couldn't restart the PC and then it never worked again.
The computer only works 1/100 times randomly or someting like that i have put a Lott of time in it and i only saw a screen 6 times. Newest BIOS on it.
It seems to be the motherboar, but i could be wrong maybe someone else ever had this problem that can help me.
