Currently experiencing a weird beeping issue with the MSI X58 Pro-E.
PC specs are as follows.
Windows 7 64bit
Intel i7 940 CPU stock clocked
6gb ddr3 corsair tri channel ram stock clocked
620 watt corsair modular power supply
ATI Radeon 5850 stock clocked
1 - Intel x-25m 160gb drive
1 - WD Black 1TB hdd
Every now and then the motherboard will just beep incessantly and then cease to beep.
There are no warning signs and no normal beep codes that I am used to.
Shall I chalk this up as a faulty board? If so I will bring it back to Fry's for a replacement since I got an extended warranty through them.
Please chime in with an answer if possible.
Thank you,
bigfil
Windows 7 64bit
Thank you,
bigfil
