msi x58 pro memory problems
tworiversuk
STAFF SERGEANT
Hi Al l,
I am really new to this type of computer building lark, I have the above board, with a 1tb sata drive , 3 sticks of 2gb memory, 1600 dominator, problem is icannot get it to run at 1600 and windows only see's 3.700gb not 6gb.All sticks are inthe right places, can anyone take me under there wing and help me with my bios settings?
regards
Mike ( UK )
Have you manually adjusted the timings (especically the command rate)?
Did you do this?
Did you clear CMOS with the main A/C power cable removed from your PSU after the update?  If you haven't, please do that next and load "Optimized Defaults" in BIOS after that.
xpm enabled
this is at 83 ratio
  2n  9 9 9 9 24
spectrun disabled
1333mhz dram
267ghz cpu
http://s681.photobucket.com/albums/vv176/tworiversuk/?action=view&current=newat83ratio.jpg
