msi x58 pro memory problems
tworiversuk
STAFF SERGEANT
Hi Al l,
I am really new to this type of computer building lark, I have the above board, with a 1tb sata drive , 3 sticks of 2gb memory, 1600 dominator, problem is icannot get it to run at 1600 and windows only see's 3.700gb not 6gb.All sticks are inthe right places, can anyone take me under there wing and help me with my bios settings?
regards
Mike ( UK )
tRFC at 83 isn't high enough for your modules; you need 88.  You need your memory ratio at 5.  Return your baseclock to 160, but change the CPU multiplier to x12.  Put the uncore on the lowest multiplier, too.
Let's not concentrate on what you can boot (DDR-1333), let's focus on getting DDR-1600 working.  I only just realised you've been trying to overclock the CPU and memory at the same time - this doesn't work.
Screenshot with CPU tweaker, not CPU-Z, also.  CPU-Z does not give enough in depth timing information.
have  to go to bed guy been at this all day 15  :sleep:hours straight,see you in the morning if you still want to help, I am so very gratfull your there
http://s681.photobucket.com/albums/vv176/tworiversuk/?action=view&current=optimizedand165v.jpg
this set to optimizes settings and 1.65 v dramm, seems fine at that,4 now
this is where i am now
1N  8 8 8  24  88
XMP Enabled
spectrum disabled
base clock 133 2.666ghz
no sure what i set the ratio at ,think it was 6
dram voltage 1.89
seem to rn going to try crysis to see if it's stable
http://s681.photobucket.com/albums/vv176/tworiversuk/?action=view&current=newsettings.jpg
this is the settins ,seems to run fine with crysis on high
May I just add my input here?
You mention the memory you are using is CORSAIR DOMINATOR6GB - 3X 2GB DDR3 1600MHZ - TR3X6G1600C8DG
I used to have 3x1GB of this stuff and the maximum I could get out of it was 1.5GHz. RMA'd it and it was found to be faulty.
Replaced it with 6GB OCZ found here: http://www.overclockers.co.uk/showproduct.php?prodid=MY-136-OC and my system's ROCK stable at 1.76 GHz 8-8-8-24 1T memory; SiSoft Sandra reports 30GB/sec memory bandwidth.
I'm not a fan of Corsair - I built a system for my Brother 6 years ago and used Corsair Value Select and that was found to be faulty too.
