MSI X870 Gaming Plus Wifi - limited speed on WI-FI
zicu11160102f1
Hello, so i made an upgrade from i9 14900k & asus maximus hero z790 to a 9800x3d & msi x870 gaming plus wifi & ssd samsung 9100 pro.
I've clean installed the Windows 11 24h2, i've updated to the latest bios 7E47v2A32(24.04.2025 release), and after successfully updated and finished everything, I installed Steam to download some games, and also tested the speed on wi-fi on speedtest, and i found out that i have an issue regarding with the speed of it, which is limited to 85-90 Mbps.
My internet connection from ISP is 1000 Mbps, I didn't made any changes regarding router or network, on my old configuration i had constantly 750 Mbps on speedtest.
Something is wrong with the Wi-Fi on this motherboard, i tried also to uninstall the wi-fi network driver, and add it manually, the Qualcomm driver from the motherboard support page, but without success.
Did somebody solved this issue somehow?
Thank you!
The drivers in the msi site are old, try this new and dowload from here: https://www.catalog.update.microsoft.com/Search.aspx?q=7800
There is a updated driver from March of 2025 ( in the msi website the newest driver is from 2024 ).
These are manual drivers that you have to extract and use device manager to point to the folder if im not mistaken.
Tell me if that have work for you.
