I can reproduce the same PCR7 binding problem on a related AMD motherboard, and I have some measured-boot log findings to add.
Configuration
Motherboard: MSI MAG X870 TOMAHAWK WIFI (MS-7E51), not the X870E model.
BIOS: 1.A93, dated 2026-09-03.
CPU: AMD Ryzen 9 9900X.
OS: Windows 11 Pro, build 26300.
BIOS mode: UEFI.
Secure Boot: On.
PCR7 Configuration: Binding Not Possible.
Kernel DMA Protection: On.
Virtualization-based security: Running.
BitLocker is enabled and protection is on. The OS volume uses XTS-AES 128, with a TPM protector using PCR validation profile
0, 2, 4, 11, rather than PCR7.
BitLocker event
Windows repeatedly records informational Event 893:
BitLocker determined that the TCG log is invalid for use of Secure Boot. The filtered TCG log for PCR is included in this event.
Findings from two binary measured-boot logs
Two separate .log files from C:\Windows\Logs\MeasuredBoot were decoded. Both parsed to the end of the file, with 41 event records each, excluding the specification header. Both include SHA-256 and SHA-384 digest banks.
PS C:\Users\rafal\Downloads\TCGLogTools-master> $TCGLog.Events
PCR0 : {@{EventType=EV_S_CRTM_VERSION; Digest=System.Management.Automation.PSObject[]; Event=05:2B:10:A7:C7:D9:65:41:81:40:2A:DD:E9:4A:F6:3C}, @{EventType=EV_EFI_HCRTM_EVENT; Digest=System.Management.Automation.PSObject[];
Event=0F:46:56:5F:4D:41:49:4E:5F:57:52:41:50:50:45:52:00:00:00:FF:00:00:00:00:00:00:B5:00:00:00:00:00}, @{EventType=EV_SEPARATOR; Digest=System.Management.Automation.PSObject[]; Event=00:00:00:00}, @{EventType=EV_NO_ACTION;
Digest=0000000000000000000000000000000000000000000000000000000000000000; Event=System.Byte[]}}
PCR1 : {@{EventType=8000000B; Digest=System.Management.Automation.PSObject[]; Event=0C:53:6D:62:69:6F:73:54:61:62:6C:65:00:01:00:00:00:00:00:00:00:44:15:FD:F2:94:97:2C:4A:99:2E:E5:BB:CF:20:E3:94:00:E0:C2:86:00:00:00:00}, @{EventType=EV_EFI_VARIABLE_BOOT;
Digest=System.Management.Automation.PSObject[]; Event=}, @{EventType=EV_EFI_VARIABLE_BOOT; Digest=System.Management.Automation.PSObject[]; Event=}, @{EventType=EV_SEPARATOR; Digest=System.Management.Automation.PSObject[]; Event=00:00:00:00}}
PCR2 : {@{EventType=EV_EFI_BOOT_SERVICES_DRIVER; Digest=System.Management.Automation.PSObject[];
Event=18:80:53:74:00:00:00:00:00:83:02:00:00:00:00:00:00:00:00:00:00:00:00:00:34:00:00:00:00:00:00:00:02:01:0C:00:D0:41:03:0A:00:00:00:00:01:01:06:00:01:01:01:01:06:00:00:00:04:08:18:00:00:00:00:00:50:FC:00:00:00:00:00:00:FF:4B:02:00:00:00:00:00:7F:FF:04:00},
@{EventType=EV_EFI_BOOT_SERVICES_DRIVER; Digest=System.Management.Automation.PSObject[]; Event=78:B1:77:74:00:00:00:00:A0:F2:00:00:00:00:00:00:00:00:00:00:00:00:00:00:40:00:00:00:00:00:00:00:02:01:0C:00:D0:41:03:0A:00:00:00:00:01:01:06:00:01:02:01:01:06:00:00:00:01:01:06:00:0
0:07:01:01:06:00:00:00:04:08:18:00:00:00:00:00:60:01:00:00:00:00:00:00:FF:F3:00:00:00:00:00:00:7F:FF:04:00}, @{EventType=EV_SEPARATOR; Digest=System.Management.Automation.PSObject[]; Event=00:00:00:00}}
PCR3 : @{EventType=EV_SEPARATOR; Digest=System.Management.Automation.PSObject[]; Event=00:00:00:00}
PCR4 : {@{EventType=EV_EFI_ACTION; Digest=System.Management.Automation.PSObject[]; Event=Calling EFI Application from Boot Option}, @{EventType=EV_SEPARATOR; Digest=System.Management.Automation.PSObject[]; Event=00:00:00:00}, @{EventType=EV_EFI_BOOT_SERVICES_APPLICATION;
Digest=System.Management.Automation.PSObject[]; Event=}}
PCR5 : {@{EventType=EV_SEPARATOR; Digest=System.Management.Automation.PSObject[]; Event=00:00:00:00}, @{EventType=EV_EFI_GPT_EVENT; Digest=System.Management.Automation.PSObject[]; Event=}, @{EventType=EV_EFI_ACTION;
Digest=D8043D6B7B85AD358EB3B6AE6A873AB7EF23A26352C5DC4FAA5AEEDACF5EB41B; Event=Exit Boot Services Invocation}, @{EventType=EV_EFI_ACTION; Digest=B54F7542CBD872A81A9D9DEA839B2B8D747C7EBD5EA6615C40F42F44A6DBEBA0; Event=Exit Boot Services Returned with Success}}
PCR6 : @{EventType=EV_SEPARATOR; Digest=System.Management.Automation.PSObject[]; Event=00:00:00:00}
PCR7 : {@{EventType=EV_EFI_VARIABLE_DRIVER_CONFIG; Digest=System.Management.Automation.PSObject[]; Event=}, @{EventType=EV_EFI_VARIABLE_DRIVER_CONFIG; Digest=System.Management.Automation.PSObject[]; Event=}, @{EventType=EV_EFI_VARIABLE_DRIVER_CONFIG;
Digest=System.Management.Automation.PSObject[]; Event=}, @{EventType=EV_EFI_VARIABLE_DRIVER_CONFIG; Digest=System.Management.Automation.PSObject[]; Event=}…}
PCR8 :
PCR9 :
PCR10 :
PCR11 : {@{EventType=EV_COMPACT_HASH; Digest=097328E8C957DE2428283954F6A1EE8FF7AD7DEF12E100A600178407F5DECF24; Event=10:00:00:00}, @{EventType=EV_COMPACT_HASH; Digest=08EFEA1C0957A5A1FE019E6EDB21FDC9FBE5DE2213487EAB7A05E06ECA1C9784; Event=FF:FF:00:00}}
PCR12 : {@{EventType=EV_EVENT_TAG; Digest=B1F8DECEBAF698B2843534372A969EB3C2F485E2390BEDE4167DBC9F68B420FD; Event=}, @{EventType=EV_EVENT_TAG; Digest=A03CB6ADE176A5C1AAD6BC7ECC21B3F6FE3B93D160ACE85939C5D83DE4E2D73C; Event=}, @{EventType=EV_EVENT_TAG;
Digest=311906AF2ABAFBDBE1BD5416DF216BAEDBD0D644A233844604685BAF1EDE84B1; Event=}, @{EventType=EV_EVENT_TAG; Digest=B9A990262310D27B47DEB737F03B598A0AD05BB5D99D4C2F2EAD972F5A274369; Event=}…}
PCR13 : {@{EventType=EV_EVENT_TAG; Digest=082AEB0D14886251143218CD33221C5E40DAF57D792BFCB70D44F43C9387E182; Event=}, @{EventType=EV_EVENT_TAG; Digest=B52791969B569247A0F53367FBE372D796D786E168BF4919B84BD889E77E0C1A; Event=}, @{EventType=EV_EVENT_TAG;
Digest=9FC5D7509AFC4DB4ED6362FF1FE8250CD2FD7A47FD8FD327B8B65BD7DEDF832A; Event=}, @{EventType=EV_SEPARATOR; Digest=4613C07447240B20CF1BAA3FD4441A3F1B62BEA1E9AAAA0678532B83CE9DE254; Event=WBCL}}
PCR14 : {@{EventType=EV_EVENT_TAG; Digest=4F4E9178DB43F4FFF2F58E95266D1F139764B2D276A8467333A12E5CEF4F8937; Event=}, @{EventType=EV_EVENT_TAG; Digest=4F4E9178DB43F4FFF2F58E95266D1F139764B2D276A8467333A12E5CEF4F8937; Event=}, @{EventType=EV_EVENT_TAG;
Digest=DCAD350A0A8B32749049723F2ECC09C0F1779A299532E4B3B3255008C28DB629; Event=}, @{EventType=EV_SEPARATOR; Digest=4613C07447240B20CF1BAA3FD4441A3F1B62BEA1E9AAAA0678532B83CE9DE254; Event=WBCL}}
PCR15 :
PCR16 :
PCR23 :
PCRMinusOne :
PS C:\Users\rafal\Downloads\TCGLogTools-master> $TCGLog.Events.PCR7
EventType Digest Event
EV_EFI_VARIABLE_DRIVER_CONFIG {CCFC4BB32888A345BC8AEADABA552B627D99348C767681AB3141F5B01E40A40E, 2CDED0C6F453D4C6F59C5E14EC61ABC6B018314540A2367CBA326A52AA2B315CCC08CE68A816CE09C6EF2AC7E514AE1F} @{VariableGUID=8be4df61-93ca-11d2-aa0d-00e098032b8c; VariableName=SecureBoot; VariableData=Sys…
EV_EFI_VARIABLE_DRIVER_CONFIG {8B0B9E7F39A21E3F15BB799EBEA8758B074F1AFE743B33E9D7CBFDCE1DE08508, 979BE5EA93B7B573BF5AB3CEED9CF124E8F28D919DB85248E9010D9D5C03CCC31D4AD04774EB46920C08C95BC011499A} @{VariableGUID=8be4df61-93ca-11d2-aa0d-00e098032b8c; VariableName=PK; VariableData=}
EV_EFI_VARIABLE_DRIVER_CONFIG {38620385637C25C84D0065762CB6BE1A937B6575B23C945C9D404F093D92DD80, A173794431E069BF65301617C0B438FD1B54E64A4F00C75E6E38C5E4A1452B23A680B115E3513DFF13BAFF0E64792568} @{VariableGUID=8be4df61-93ca-11d2-aa0d-00e098032b8c; VariableName=KEK; VariableData=}
EV_EFI_VARIABLE_DRIVER_CONFIG {79ED9F64EA6325005833E1BECF6214BD2EB4ADFA4E8143E138CB5758AC4996A6, 9842D999362AECAEDE38917192BDAA6FB27B42B7BE6511E5FDC4393E8E4D6FAF23C26520E866F74B09531692AE585BCF} @{VariableGUID=d719b2cb-3d3a-4596-a3bc-dad00e67656f; VariableName=db; VariableData=}
EV_EFI_VARIABLE_DRIVER_CONFIG {6E0DFC8709F8BE1C6F11B2569DCC996A723E0EBAA46C3860C346EA6DACDB32C1, 81A0CD59A8A5EA638943307A8196098BBE60F77CB2F670F37908CC1E4E33A7E939657F54743F2BD7E5AC86C5A8697002} @{VariableGUID=d719b2cb-3d3a-4596-a3bc-dad00e67656f; VariableName=dbx; VariableData=}
EV_SEPARATOR {DF3F619804A92FDB4057192DC43DD748EA778ADC52BC498CE80524C014B81119, 394341B7182CD227C5C6B07EF8000CDFD86136C4292B8E576573AD7ED9AE41019F5818B4B971C9EFFC60E1AD9F1289F0} 00:00:00:00
In both logs, PCR7 contains only:
EV_EFI_VARIABLE_DRIVER_CONFIG — SecureBoot
EV_EFI_VARIABLE_DRIVER_CONFIG — PK
EV_EFI_VARIABLE_DRIVER_CONFIG — KEK
EV_EFI_VARIABLE_DRIVER_CONFIG — db
EV_EFI_VARIABLE_DRIVER_CONFIG — dbx
EV_SEPARATOR
There is no
EV_EFI_VARIABLE_AUTHORITY event anywhere in either binary log—not just in Event 893’s filtered output.
Both logs nevertheless record the image load of:
\EFI\Microsoft\Boot\bootmgfw.efi
into PCR4 and continue with subsequent Windows measurements. Therefore, the files do not simply stop before Windows Boot Manager loads.
Replaying the newer log’s SHA-256 PCR7 measurements produces exactly the PCR7 digest reported in Event 893.
Windows measured-boot health summary
The matching JSON reports:
HealthStatus = Attestable
TpmPresent = true
TpmMeetsMinimumVersion = true
TpmIsResponsive = true
AttestationCertIsAvailable = true
TcgLogFound = true
PcrsMatchTcgLog = true
SecureBootEnabled:
ValueFromComputer = true
ValueFromTcgLog = true
TcgValueIsVerifiable = true
In other words, Windows reports that the PCR values match the log, while BitLocker rejects that log for Secure Boot/PCR7 use. These are not necessarily contradictory: replay consistency does not establish that the required authority measurement is present.
What this establishes
The evidence supports a reproducible missing-authority-measurement problem in the recorded boot path. Microsoft documents missing or malformed OS Loader Authority measurements as reasons BitLocker cannot use Secure Boot for integrity validation.
"If the system has TPM2.0, PCR [7] support is required. Otherwise, PCR [7] support is optional. Tree EFI Protocol specification has details about PCR [7] support."
"BitLocker cannot use Secure Boot for integrity because the expected TCG Log entry for the OS Loader Authority is missing or invalid."
Source:
https://learn.microsoft.com/en-us/w.../testref/954cf796-a640-4134-b742-eaf0ed2663ff
The clearly unmet condition is the presence of a valid
OS Loader Authority measurement in PCR7. Microsoft requires an EV_EFI_VARIABLE_AUTHORITY event describing the Secure Boot database entry that authorised the Windows boot loader.
