pdpodobinsk157a02da
- Jun 24, 2025
Problem Description:
CPU Temp sensor gets stuck anywhere between 55 degC-65 degC.
After loading the system temp reporting works ok, when you put any stress on CPU,
after 1-5min telemetry stops working. This happens both in Windows and in Linux.
It doesn't matter which application is used to monitor the temp, same thing can be
observed in HWInfo or in MSI Center, or in Linux lm-sensors
Unfortunate side effect of this is that CPU fan also gets stuck at higher
speeds, whole curve temp control becomes useless.
Any ideas?
Any ideas?
