Msi z690 a pro wifi ddr4 missing driver??
doug.hogart153b02d9
Active member
Per the last step of citay's mentioned post, if you are connected to internet, check Windows Update-Advanced Options-Optional Updates to see if there is a "Driver" something like Micro-Star INT'L CO., LTD. - System
wasakiqwe
Thanks, solve it.
Do you know if there is driver for USB?
my keyboard and mouse feels slow in games.
Pro
No, USB doesn't need any drivers, the Microsoft default one is used. What do you mean, "feels slow"?
doug.hogart153b02d9
Active member
If your mouse/kb is wireless and the transceiver is plugged into a rear port, try moving transceiver to a port on the front or top of your case. Or try using a short USB extension cable to get transceiver away from rear of your case. Sorry I am not a gamer so don't know any potential optimizations such as display settings or whatever.
