My last BSOD detailed.
Can this help you???
[size=18pt][size=8pt]Microsoft (R) Windows Debugger Version 6.3.9600.17237 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\090614-6296-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Symbol Path validation summary **************
Response Time (ms) Location
Deferred Symbol File Path: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: Symbol File Path: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff800`d1680000 PsLoadedModuleList = 0xfffff800`d194a2d0
Debug session time: Sat Sep 6 12:17:37.307 2014 (UTC + 1:00)
System Uptime: 1 days 0:13:34.150
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
************* Symbol Loading Error Summary **************
Module name Error
ntoskrnl The system cannot find the file specified
You can troubleshoot most symbol related issues by turning on symbol loading diagnostics (!sym noisy) and repeating the command that caused symbols to be loaded.
You should also verify that your symbol search path (.sympath) is correct.
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {20, 2, 1, fffff800d16e1ade}
*** WARNING: Unable to verify timestamp for hal.dll
*** ERROR: Module load completed but symbols could not be loaded for hal.dll
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+61ade )
Followup: MachineOwner
0: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000020, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff800d16e1ade, address which referenced memory
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff800d1680000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 53388e13
WRITE_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPagedPoolEnd
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
0000000000000020
CURRENT_IRQL: 0
FAULTING_IP:
nt+61ade
fffff800`d16e1ade 0102 add dword ptr [rdx],eax
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
ANALYSIS_VERSION: 6.3.9600.17237 (debuggers(dbg).140716-0327) amd64fre
LAST_CONTROL_TRANSFER: from fffff800d17dfae9 to fffff800d17d3fa0
STACK_TEXT:
fffff800`d354a828 fffff800`d17dfae9 : 00000000`0000000a 00000000`00000020 00000000`00000002 00000000`00000001 : nt+0x153fa0
fffff800`d354a830 00000000`0000000a : 00000000`00000020 00000000`00000002 00000000`00000001 fffff800`d16e1ade : nt+0x15fae9
fffff800`d354a838 00000000`00000020 : 00000000`00000002 00000000`00000001 fffff800`d16e1ade fffff800`d161658f : 0xa
fffff800`d354a840 00000000`00000002 : 00000000`00000001 fffff800`d16e1ade fffff800`d161658f 00000000`00000000 : 0x20
fffff800`d354a848 00000000`00000001 : fffff800`d16e1ade fffff800`d161658f 00000000`00000000 00000000`00000000 : 0x2
fffff800`d354a850 fffff800`d16e1ade : fffff800`d161658f 00000000`00000000 00000000`00000000 00000000`00000000 : 0x1
fffff800`d354a858 fffff800`d161658f : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt+0x61ade
fffff800`d354a860 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal+0x658f
STACK_COMMAND: kb
FOLLOWUP_IP:
nt+61ade
SYMBOL_STACK_INDEX: 6
SYMBOL_NAME: nt+61ade
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
BUCKET_ID: WRONG_SYMBOLS
FAILURE_BUCKET_ID: WRONG_SYMBOLS
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:wrong_symbols
FAILURE_ID_HASH: {70b057e8-2462-896f-28e7-ac72d4d365f8}
[/size][/size]
