MSI_LED error
RIY
MAJOR
What is your mb? win10 verison,1903?
Can you list what msi software you have installed?
dpullin14d602d1
sorry to squat on this outdated thread but it was the only one with reference to msi_led.exe error..
i'm getting an event message every once and while when i boot up..
- <Event xmlns=" ">
-<System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Level>2</Level>
<Task>100</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2021-02-23T16:38:03.702703700Z" />
<EventRecordID>36708</EventRecordID>
<Channel>Application</Channel>
<Computer>xxxxx</Computer>
<Security />
</System>
- <EventData>
<Data>MSI_LED.exe</Data>
<Data>6.2.0.96</Data>
<Data>f3f2611b</Data>
<Data>KERNELBASE.dll</Data>
<Data>10.0.18362.1316</Data>
<Data>7a6bfa05</Data>
<Data>e0434352</Data>
<Data>001146d2</Data>
<Data>3b54</Data>
<Data>01d70a022f70711a</Data>
<Data>C:\Program Files (x86)\MSI\Gaming APP\MSI_LED.exe</Data>
<Data>C:\Windows\System32\KERNELBASE.dll</Data>
<Data>b356299a-7b72-4702-8c2a-c97f4e4800b7</Data>
<Data />
<Data />
</EventData>
</Event>
msi motherboard and graphic card..
B450 GAMING PRO CARBON AC
Radeon RX 580 ARMOR 8G OC
win10 build 1909
any ideas whats wrong with your software?
eqwebbie_with_PC
Experienced Dummy
Thanks, my software is fine, but yours seems a bit faulty.🤣
You know this forum is "users helping users", do you? 😉
If you don't need MSI gaming app (who needs it, anyway?), deinstall it and your error messages should disappear.
Administrator
What MSI software exactly you are using that you got this error?
And when this started? Does it worked fine before?
dpullin14d602d1
looks like it started june 4 2020.. and its part of the gaming app installation.. the software was installed 2019-11-28 so its been working till june 2020. i'll try re-installing the software..
