MX460 VTP & W2K video in/out problem
  • Thread starter Thread starter Adde
  • Start date Start date
A
Adde
Guest
i have bought the card as described but i can't activate the nView (tv out) function in Windows 2000.
I've tried to install and uninstall a lot of drivers but tothing happen.
Wath must i do ?
Drivers 30.82
Bios 30.06
WDM Drivers 1.1.6
Thanks
I also had trouble activating the nView function. The only way I could get TV out, was by using TVTOOL. I do not believe that TV Tool supports MX cards, but u can check it out here:
TV Tool
Wath must i do ?
Drivers 30.82
Bios 30.06
WDM Drivers 1.1.6
Thanks
X( i check out at tv tool web page an i discover that the gforce 4 mx is not supported by that soft. so please to the developers of the graphic card give th specs so we can switch between vga and tv
Your card is suported by TVTool.. TVTool don't support GeForce 4 MX with internal (NV17) Tv encoder, but the MSI GeForce 4 (MX460 VTP) use an external tv chip (philips saa 7108 ) which is suported by TVTool. I have the exact same card as you and TVTool work like a charm. Or you can also go back to NVIDIA reference driver version 28.32, they are the only one who make my tv-out work with this card... (but with TVTool, it work with any driver)
and thanks to everyone reply me.
I solved with tvtool 6.5, great utility, but si it possible that you MUST use another utility than nVidia & MSI driver to do that they advertise ????
ok another question
is it possible to have other resolutions for TV out ????
Sorry for my english, i'm italian.
Ciao
