My 144hz monitor, after two weeks of not using it, dropped to maximum 120hz.
Lawliet
I don't know why, I haven't messed with any settings to my knowledge. The monitor is roughly 3 years old and has worked fine till then, I'm also still using the same HDMI cable I did two weeks ago. Can anyone please help?
Do you use NVIDIA graphic card? If so, please adjust your screen resolution. In the NVIDIA Control Panel navigation pane, under Display, click Change resolution to open the Change Resolution page. Under “Choose the resolution,” select the maximum resolution under PC, and then check if this helps resolve the problem.
My NVIDIA control panel doesn't have a display settings
