My 240W delta 15 charger is died after just 2 days
I bought msi delta 15 from best buy, and i am not from NA so i cant return it, my charger has rating of 20V 12A, is it ok to use 19.5V 12.3A adapter?
Or can i use lower power charger?
drek4
Active member
PRIVATE FIRST CLASS
Well technically it should work if less than 0.5v difference, but it's always best to purchase one that is specified for your laptop.
Ummm, how did the charger die?
Just use under normal circumstances? or? :think:
It wasn't even plugged to laptop (only plugged to the outlet), i was using the laptop when the battery reached 30% i tried to charge it and the adapter wasn't working. I took it to local service and they said the adapter is dead and can't be fixed.
drek4
Active member
PRIVATE FIRST CLASS
There is an Asus adapter that works with 20V 12A output, iam trying get that and change the pin.
If you change the pin, it becomes no longer specified for your laptop, it's better to have the same pin and specs.
next3r
MAJOR
same PIN and same Volt :bonk:
if you have 20V OEM ,..,need 20V not 19.5V
next3r
MAJOR
and how did you find out that the PSU is dead ??
most time need only EC RESET
