my Creator 15 A11UE graphic card its making my screen flick
felipordi153e02d9
sometimes it help to switch from HDR on to HDR off to stop it or slow it down for some time. Also some times it does not flicker, it just make a line that cuts my screen horizontally that appear and disappear.
in the link some examples
Kujou
does the problem only happens when you using google chrome? or the problem happen in all yous applications you use?
felipordi153e02d9
it happens in general. while playing videogames, while watching movies, or web searching. But its more often when i am gamming or whatching movies. i belive it must have something to do with the graphic card. its an
Intel(r) UHD Graphics
NVIDIA GeForce RTX 3060 Laptop Gpu
I recommend you install the latest version of BIOS and reinstall Intel Graphic card driver from MSI official website.
Those version of software should work properly becasue they are verified and tested by the laptop.
BIOS->https://download.msi.com/bos_exe/nb/E16V4IMS.317.zip
Intel Graphics Driver( 30.0.101.1340)->https://download.msi.com/nb_drivers/vga/16V4_Customized_win64_P_1.zip
The website.->https://www.msi.com/Content-Creation/Creator-15-A11UX/support?sub_product=Creator-15-A11UE#driver
