My First PC Build MSI B450 Tomahawk + Ryzen 7 1700
Status
Not open for further replies.
imhassanpiracha
CORPORAL
Hi All,
This is my first custom build after 8 years. I have found that the B450 Tomahawk is a great product and goes really good with the Ryzen 7 1700.
I am currently Rocking the following Specs:
1. MSI B450 TOMAHAWK MOTHERBOARD
2. AMD RYZEN 7 1700 OC @3.6 GHZ (With stock Wraith Spire Cooler) at 1.15 Volts.
3. DDR4 2400 MHZ from TEAM DELTA RGB 8 GB OC to 3200 MHZ at 1.25 Volts
4. ZOTAC GTX 1070ti AMP EXTREME EDITION also OC to 2025 MHZ
5. TEAMGROUP 480 GB SSD
6. EVGA 550 Brozen Fully Modular PSU
7. I have all this sitting is the COOLER MASTER LITE 5 RGB Case that comes with three FRONT FANS PRE-Installed and one EXHAUST.
ALL RGB GOODNESS IS FLAWLESSLY CONTROLLED BY MSI MYSTIC LIGHT SOFTWARE :))))[attachthumb=1][attachthumb=2][attachthumb=3]
keith_starkey
Nice rig!
Say, did you find that you have to flash update your BIOS?
I just received the last part I need to begin building my new system (Tomahawk B450, Ryzen 5 2600, NVidia 1030, I think it is), and I'm wondering if I should prepare to update the BIOS as well. I'm not building this for gaming, and the only adjustments to the motherboard will be to run XMP so that I can squeak something more out of the inexpensive memory I bought. Otherwise, it will be a plain-jane system.
Thanks
miklet
SECOND LIEUTENANT
Impressed with your low voltage overclock on the RAM
Status
