My gtx 1080 aero fan is running really high speed.
So i have 1080 aero from msi and sometimes the fan is running more than 100% and theres nothing i can do. I have tried using msi after burner but it doesn't work when the fan is doing it. The sound is just awful im glad i have noise cancelling headphones but does anyone know what to do?
darkhawk
I'm not sure that you can actually control the fan speed on the AERO GPU's.
What is the GPU temperature when this happens?
Aero cards are using the old nvidia refrence design blower fan. It does not have much potential. It is normal to run at high speeds.
Administrator
100% of what?
What temp GPU reach and with what FAN %?
You can try to undervolt the card to reduce the noise,
but check if there are another issues 1st.
Also clean the turbine with dust blower will also helps.
Of course you can.
