my msi center has no option for adjusting fan speed and more, it came with msi center and it was working before but it is gone now.
kiratjohal15ad02e9
My laptop is fully supported. I used the MSI Center Cleaner, but it didn’t help. I also flashed the BIOS once, about a month ago, to try and fix this bug, but that didn’t resolve the issue either. I even reset Windows and am now back on Windows 11, but the problem persists. I am open to any suggestions. According to MSI support, I would need to send in the laptop, which could take up to half a month or more, as I understand.
did you try msi center clean removal tool and instal msi center again? also you can only adjust fan speeds in high performance mode.
or you can try this msi center alternative, its not very easy to use but it works
yea tried to reinstall, i cant even change modes as it isn't an option to install that feature at all anymore, thanks a lot for the alternative that will probably help. its been months and atp i might as well send it in to msi for the rma repair under warranty.
