I dont know whats wrong I need to wait 1 day fort it to turn on and then wait 2 days more my bios is updated my ram is Good nothing is wrong can someone help me
I use a msi x670e gaming plus wifi but its around a day because my pc is Now on but if i game for around 2 days or 1 i need to wait around a day i can send a vid of my pc if you want
and list the spec, test single ram only on slot 2 with EXPO/XMP off and see if problem persists. If it's okay, add the memory back and see at which points, the system stuck at DRAM LED. Also, make sure the BIOS is up to date.
If PC still doesn't work without EXPO, then you need to check the CPU socket and see if there's any bent pin.
Or if you're using dram from random manufacture?
