My side tempered glass panel of MSI FORGE 100M shattered on its own!
chinmay160151102d2
So while cleaning my PC I was removing the side panel real slow and being careful. After I removed all the 4 screws and kept them aside I got back to the panel as the panel left the surface it shattered on its own like an explosion! I was shocked when that happened. Anyone got idea? I tried contacting MSI waiting for their reply. I expect a free replacement of side panel.
GENERAL OF THE ARMY
I wouldn't hope too much for that. A shattered sidepanel looks much like a user error. The glass is really sturdy it takes some force to shatter it.
ulukante156802e4
The tempered glass side panel of my MSI Mag Forge 100M case has shattered in a thousand pieces.. I need a replacement side panel but i dont get a response from msi. i expect them to have a quicker response time since its a big company, anyone know how long it takes for them to respond? i have also been sitting in the live chat waiting list for an hour now.
ulukante156802e4
Update: They have responded to me finally, although the response didnt help me out completely it did help me a bit forward, they told me who i had to contact for the parts so i did. Now im waiting for them to respond or confirm sending it to me.
Who did you contact for the replacement glass? I need one for my MSI case as well. Mine didn't break but I'm not a big fan of the tinted glass that the MPG GUNGNIR 100 comes with. I see what they were trying to do with making the case look very Stealth Fighter liked design but it does affect the lighting in the case by what appears like a 50% decrease in brightness. It looks like MSI decided to go with privacy glass and not tint film. Which is better aesthetically and durability wise but makes it impossible to remove due to the fact that the tint is actually baked into the glass.
d4run44151a02d3
The glass on my Gungnir 100 case also exploded into a million pieces. I've had no luck with MSI support. Can you tell me who they told you to contact? BTW - was a just setting the panel in place to screw it on and it exploded in my hand. There was no impact, no binding, no anything that I can attribute to making it shatter. I was floored that it happened. Thanks for your help.
hol158c02e2
Any chance you can share the contact info for the replacement tempered glass supplier? My Trident X Plus shattered recently as well. Totally my fault, but I need to replace it anyway. Thanks in advance.
teletubby_po
To infinity and beyond.
FIRST LIEUTENANT
@hol158c02e2 hi there you can contact MSI service directly and select warranty for your ticket category.
Global support:
For global support queries you have to register at https://register.msi.com/. After registering and logging in go to "My Support" and "Ask For Support" which allows you to issue your problem.
tv15d402e8
I broke the glass of my MSI MAG FORCE 100M, but i cannot ask for support on the website as it refuses to accept my serial number.
strange because it accepted my serial number when registering the product in the member zone.
So please don't tell me to use the support on the website as it doesn't work... it's very frustrating, been trying for 2 hours now.
how can i ask for a new window or where can I buy/get one ?
please help
thank you
plutomate
MAJOR GENERAL
weird, if you log in to the member center and try to submit a ticket, at my product section, you can simply select your previously registered product and it fills out the correct serial number for you. Did you try that?
Also, some country does offer hotline service that you can simply call them and get help.
impcservice157902de
Hi, I found your story of the glass shattering. I don't believe it is user error. I just took 2 of the screws off a MAG case and while holding the other one the glass just exploded. No force on it, nothing. It just blew up. Then you could hear the glass making noises and literally jumping off the bench. Never seen this before. I took a video of the sound and the glass. Did MSi end up replacing your panel. I seriously believe these are defects. Let me know please. There are more stories regarding these exploding tempered glass sides.
impcservice157902de
I just posted about a side panel I was taking off exploding also. No force, nothing. Had the case laying flat and took out 2 screws and went to take out the other 2 and the glass just exploded everywhere. Cutting my hands and leg. The ridiculous thing is I was needing to replace a 240mm Mag Cooler for the second time, I think the pump has failed again. MSi need to address this sort of thing. I'm not letting it go.
martin.nike15e702ee
Hi there, got the shock of my life from this, the glass literally exploded and that was from tapping it down 1mm. The sides aren’t protected and though someone mentions it’s ‘tough glass’.. it probably is… from the sides.
on the edges though it’s not protected and something like this is potentially dangerous. I have logged a ticket about mine because you can’t say that it should do this from a 1mm movement down onto a surface.
I can see lots of people complaining of the same so I expect this is maybe something they want to take seriously and protect the edges of the glass or risk something more ‘problematic’ happening..
drakeism158602dd
I called support directly at 1-888-447-6564 went to desktop support and they have an option to speak to someone about parts and accessories purchases and the associate I talked to emailed me the info to purchase a replacement front panel for the 110m
Alan J T
Demon God
Not sure you should be able to take measurements with a ruler or tape measure
