You may want to block Updates to the program then.i fixed mystic light issue by my self t doing some work around and result is now mystic light never give up again not permanent but for some months or a year![]()
i fix it with some workaround and i found a major issue with dragon centre but i dont know if its work others or not just i check to chip no then its possible to anyone they have chip on motherboard that control the audio and LED device sync other than nahimic is also internal USB device in like LED uses also LED firmware using windows xp 64bit driver thats the issue sometime its crash and light going off crash i am not sure about 100% but i still work on it what things really happen to nahimic and LED`s because both doing same things if LED working fine then nahimic creat sound crackling if LED create problem then Nahimic running fine ... thats mean both are not work together fine at same timeYou may want to block Updates to the program then.
