Mystic Light - not showing MSI 3060 Ti gpu
jhurst0159302e6
This topic might have been discussed already in this forum, but couldn't find it. Anyway my MSI 3060Ti Gaming X is not found in Mystic Light for syncing RGB. One of the purposes of buying an MSI gpu was to match my MSI motherboard, to make syncing easier. The MB and RAM show up properly in Mystic Light also.
I've tried reinstalling MSI Center/Mystic Light multiple times, and other GPUs show up (had a 1070Ti Gaming X before), just not this one. Any ideas?
Running Windows 11 with an MSI Z590 motherboard with latest BIOS/chipset/drivers. Device Manager properly shows the MSI 3060 Ti card, and I am able to control fans for the card in MSI Center, just won't show in Mystic Light. :(
keith3_16
CORPORAL
Have you checked for GPU BIOS update?
jhurst0159302e6
Ok Keith#3, I think you may be onto something. I checked GPU-Z and saw that my GPU has a MSI Ventus BIOS flashed to it, and it's actually a Gaming X card. So it has v94.04.46.00.DE (Ventus 2X OC V1 LHR) and it probably should have 94.04.38.40.A9 (GAMING X). However, when I try to flash it with nvflash it gives me error: "ERROR: GPU PCI Device ID mismatch."
**UPDATE was able to get it flashed to the proper GamingX BIOS, but same issue with Mystic Light not recognizing it. Which makes sense as it seems like if it was going to work it would have worked with the Ventus BIOS as well.
