Mystic light usb bug
I posted on Reddit but found no help there, I decided to install dragon Center to control gpu rgb and had a complete nightmare with it so i uninstalled it however an issue persists afterwards, everytime i plug in a usb device i get a notification from windows that says it is currently setting up mystic light. I’ve tried formatting and reinstalling windows and unplugging all usb devices whilst doing so and it still shows up, does anyone have any idea what’s causing this? Even when i unplug usb devices it pops up...
Specs
3700x
B550 tomahawk mag
teletubby_po
FIRST LIEUTENANT
How did you uninstall mystic light? Did you just delete the app under Dragon Center or a complete uninstallation that delete UI and SDK?
I completely uninstalled it, there’s no traces of it on my pc, I’ve even formatted and reinstalled windows countless times, very annoying
fatedust
FIRST LIEUTENANT
Which BIOS version are you on? Are you on the latest verison 7C91vA2?
Administrator
MSI able to duplicate this issue, they are working on a solution.
Thanks for your patient.
Administrator
not sure what solution they will make, but will provide it to you asap, once its ready.
Thanks a lot, what are expected boot times on the b550? Does more usb devices slow the boot down? Currently getting 14 seconds on a Samsung nvme 970 evo plus, is this good? It’s my first experience with an m.2 drive
Administrator
Nah, no ETA.
But its now done:
Nah, no ETA.
But its now done:
file doesnt show up in mflash when i put it on a usb stick?
edit nevermind fixed it, problem resolved thanks!
fatedust
FIRST LIEUTENANT
I just took a look at the BIOS file and it said "E7C91AMS.A41". Did you successfully flash to this version?
Correct I did, i believe this time around its not mystic light as mystic light is port 0012 0001
edit
however when i disable the device, it disables my two corsair products, im so confused to whats actually going on here.
just a little update, did a few tests with certain things unplugged and the culprit is my glorious model o mouse if that helps you with a solution, that’s the device the disconnects and reconnects upon logon, tried a different mouse and no usb disconnect sound on startup
Nah, no ETA.
But its now done:
any chance you could pass this recent issue on? It’s nothing overly major but it’s still something that shouldn’t occur, nothing to do with my Corsair products, it’s the glorious model-o mouse that disconnects and reconnects at login screen
