Mystic Lights and CPU monitoring disappeared from MSI centre
erwinlia15ca02e9
I have a /MAG-B760M-MORTAR-WIFI board and recently ran into a lot of issues with my Rx6600XT card.
After numerous installation, I managed to get the RX6600XT running with an older driver without sleeping.
I also updated my Board's to the latest bios. Then for some reason, my MSI centre no longer shows mystic lights and CPU monitoring.
I tried the removel and install tool for MSI centre but the results are is the same. They all came back blank. What should it do next ?
Hi there,
I tried that . I used the cleancentre master. Infact after it wipe out my MSI centre. My Msi came back with totally no Mystic light. Initially everything was working, then mystic lights only showed my Rams RGB. Now The CPU monitoring and Mystic lights are gone and there are no options to install them upon my reinstallation. Could this has something to do with my DDU installation of my RX6600XT cards driver ? Should I try and use dragon centre ? BTW I did update to the lastest bios and tat seems to have worsen the situation. I am also unable to revert back to old bios since the Flash Bios look at older version as invisible files
Please update to MSI Center 2.0.19
https://download.msi.com/uti_exe/mb/MSI_Center_2.0.19.0.zip
Look like you try to install hackintosh before and it completely wipes your model name which breaks the support of MSI Center.
You either need to write the model name back with special tool (if you manage to find anywhere) or you'll have to rma it. :bonk:
