need help for driver instllation
salvation_am
i have a CPU with MSI C236A workstation motherboard. and i have installed windows server 2016. i have installed all the driver but i couldn't find a driver for network. can anyone help with network driver .please
Hi ,
Haven't you received a installation cd-rom? Double check all the products boxes.
Otherwise ,try to find your driver using internet on a separate machine and put it on a USB stick . Go to device manager on the new machine and update/install your hardware drivers.
Hope this helps
,Cheers
Yes, what exactly is your problem? You don't have the disc? If you  is the problem drivers on the disc don't work? If that's the problem maybe you can try the drivers for Server 2012 as they don't have drivers listed for 2016. >> drivers Intel  I219-V LAN  <<
 Select the OS in the right hand drop down menu.
i have driver cd but a driver doesn't listed for server 2016. i tried manually from device manager with windows 10  driver too and the link u have given for intel, i have tried that as well. but not working. could it be because of new os. one thing what i don;t unerstand is every driver is installed except network
why msi doesn't make driver for server os.
Because MSI doesn't make drivers.......
It's an Intel LAN, which means Intel would provide the driver.
Apparently there is no driver for 219v for server 2016. You may be able to get the lan working by installing the driver for 219lm.
If you have a device manager GUI, update the driver on the unknown network device and select Intel i219lm.
Official driver for server 2016,  but i219v not listed under supported devices.
https://downloadcenter.intel.com/download/26092/Intel-Network-Adapter-Driver-for-Windows-Server-2016-
