Need help if it fits!
Status
Not open for further replies.
hyper 212 will totally fit as long as your case has the height. the Noctua NH-D15 will fit but the only problem as its so huge if the Graphics card you have has a backplate it may not fit as it will be sat right up against it
thanks for the reply,
my current set up is
cpu 3600x
gpu: rx 5700xt gigabyt gaming OC
board: msi b450m mortar max
ram: 2x8 hyperxfury black
looking at the stock cooler, it has a clearance or around 1/2-1inch from the ram, and the videos on youtube looks like the nh-15 is massive that is why I asked. Will just go with what you have suggested. Thanks.
Status
