Need HELP on MSI A320M PRO-E BIOS UPDATE
hi why i cannot find the files of BIOS on USB. i want to change my proc from ryzen 3 3200G to ryzen 4 4350G but i need to update my bios
i read on this forums there is a problem on this model A320M PRO-E
Bios Version: E7A36AMS.i00
Reason its not Seeing it is Because you have a OEM Motherboard that was used in a pre-built PC not a Retail Version so its using a Different BIOS Version and you would need to Crossflash the BIOS to the Retail Version that you can learn about here: https://forum-en.msi.com/index.php?threads/msi-a320m-pro-e-e7a36ams-i00.398123/#post-2264871
Is there a new BIOS update that might fix this issue? The USB ports on my motherboard aren't working properly—they won't detect some of my USB devices. I also tried plugging the same devices into different motherboard USB ports, but the problem is still the same. Some devices are simply not detected.:sad:
By the way, my current BIOS version is E7A36AMS.143.
