jamesforbes198157e02db
- May 31, 2023
first and foremost, hi my name is jim.
my setup-
gigabyte x570s gaming x.
amd ryzen 9 3950x 16 core.
msi amd rx 6700 xt mech 2x OC 12gb.
corsair vengence 64gb @ 4000mhz.
nzxt 850w ghost quiet psu.
arctic freezer 2 360mm.
my pc case is always open ie sides removed.
msi afterburner (latest).
modified win 10 home os (with all the crap removed, bare bone os).
All settings are stock, i have never in all my years have had the need to overclock/underclock anything (but i would really like some help here if you can please).
This is the short story version,i bought a new 65" tv (i always use tv;s for gaming as my eye balls are garbage,i wear glasses),this tv i have been saving up for, she has amd freesync and 2 x 120hrz hdmi ports (that im using) everything is fine so all good,but because its 120hrz and not my usual 60hrz the card is getting hotter and i dont l;ike the fans blazing like the wind.I have been watching utube vids and and the curve editor on there is different than mine (mine has 2 curves not 1) frequency mhz and voltage,and also i cant move the memory clock back as the slider is all the way back (i can only slide to the right ie only go higher. stock 2000mhz), core voltage and core clock can be slid back and forth no problem fan editor is fine so can someone explain to me please do i use core clock//core voltage//memory clock for undervolting,i have installed afterburner//hwinfo//furmark (i like furmark i use it all the time for testing out settings) i would tried to use adrenalin but when i hit the undervolt button the pc never came back on (so i would like to learn to undervolt this way taking easy steps first.so what do i do please?.
so we have 3 things core clock/ core voltage/ memory clock (ill adjust the fan as and when needed.
thanks jim. ( i know its long overdue to learn this)
my setup-
