network problem-post hubs etc do not work with onboard lan
Wonkanoby
GENERAL OF THE ARMY
please just the facts and no debates and keep to just items that did not work
full details please make model etc
please as well your network driver
mines 27/11 2002 3.13
R
RobRobinson
Guest
pease as well your network driver
Heres mine..
Astrolink CT1009D1 9 port 10mbps "High Performance (yeah right)" Ethernet Hub.
7/10/2002 2.6.1.0 Driver.
Symptoms: Slow or no connection with onboard NIC, happy as clam with add on cheapo NIC
K
Kobra
Guest
My hub is a Linksys 5 port workgroup hub model # EW5HUB
driver is Nvidia dated 9/23/02 ver 2.8.1.0
no connection at all thru hub, work connected to Linksys ROUTER and also when connected directly to my cable modem
Kobra
A
AofI
Guest
StarTech.com 10BT 5port hub m#:er539580702710447
Nic Driver 9/23/02 Ver. 2.8.1.0
T
tfec
Guest
3Com® OfficeConnect® Ethernet Hub 8, #3C16700A
No link; driver version had no effect on the problem
Wonkanoby
GENERAL OF THE ARMY
First of all, user need to check if the MAC address was there like execute this command on DOS mode "ipconfig /all "
After that, we can determine if this is function problem or compatibility problem
can you all try this and post what you get please
i would add try programmes accessories command prompt and type in dos box there
K
Kobra
Guest
my mac address is as listed on the sticker on my board.
Kobra
Spectre-63
Hi all -
New K7N2-L, WinXP or Win98SE, latest drivers and while I show link and (in XP) get an IP address, I'm unable to ping. MAC address is correct.
Hub is NetGear FS105 (5 port Fast Ethernet Switch). Old 3C905TX board works just fine.
Any ideas on a solution ETA?
Thx!
T
TristanH
Guest
Just recieved the k7n2-L Motherboard.
I cannot get an IP address going through my D-Link DE-805TP hub (5 ports).
Plug in a network card, and it works fine through the hub. Plug the onboard lan directly into the cable modem, it works fine.
Just will not work through the hub. Spent a lot of time with D-Link phone support last night, couldn't come up with anything.
Updated to latest BIOS and drivers just to be sure.
A
AofI
Guest
Originally posted by Spectre-63
Hi all -
Thx!
What is the ip address it gets in xp? If xp doesn't get an IP from a DHTP server, it will assign its own. I don't remember what it is, but it still will not work.
I talked to a friend of mine who is a computer engineer, or will be by the end of this year. He said ?I know enough about networking to know that the mac addy has nothing to do with this problem." He thinks it might be the way the nic handles Collisions compared to the hub.
Hope this helps.
Spectre-63
AofI -
I am a Network Engineer.
If the NIC doesn't get a DHCP assigned address it will use an APIPA address (Automatic Private IP Address) in the 169.254.x.x subnet. I tried the onboard NIC with both an assigned address and a DHCP address - neither worked. The ability to select a MAC address in BIOS (somewhat dangerous IMHO) is the reason they're asking what MAC address is coming up.
I also attempted connecting the onboard NIC to the cablemodem directly and still had no success.
M
meier
Guest
me just pluged in a external networkcard and it works fine. if the onboard card is really working in any way ?? this shoud stand in the user guide . Its a big,big bug !!
A
AofI
Guest
I know that some ADSL providers rely on your mac address in order for access to there system, but cable modem providers do not, or at least mine doesn?t. So if you can?t connect by going strait to the cable modem I would say the nic is faulty or the Ethernet cable.
No offence Spectre but I could spend two years in any number of ?technology schools? such as ITT Tech and call myself a Network Engineer. You sound like you know what you?re talking about so I?m assuming you are more experience then the Network Engineers I am accustom to talking to.
Spectre-63
AofI -
none taken - I know a number of the "Network Engineers" you refer to - most hold the Microsoft MCSE which, in their cases stands for:
"Must Consult Someone Experienced"
or
"Minesweeper Consultant and Solitaire Expert"
:D
Luckily, 6 years of field experience as a Novell CNE has done me a bit better :D
K
kri
Guest
Here's my problem:
I'm using an Alcatel DSL modem (not the USB version, the one which has to be connected to the network controller) to connect to the internet. Now i got a K7N2-L and found out that i couldn't connect anymore. It said that connection to the VPN server couldn't be established. I put in my old network card (3Com TC-900B TPO-Ethernetadapter) and it worked just fine. I looked at the settings for the 3Com card and I set the ones for the onboard controller just like them... still didn't work. My drivers also seem to be up to date (2.8.1.0).
Does anyone know what to do?
thx
kri
specs:
MSI K7N2-L
Athlon XP 2000+
MSI GeForce3 Ti200
MSI DragonWriter 48/16/48
Maxtor HDD
Win XP + SP1
EDIT: i forgot to mention, i was on a small LAN party recently, and the onboard LAN worked fine there... the problem only seems to be with the internet.
B
backwoodz
Guest
are you using the provided mac address that came on the board?
Wonkanoby
GENERAL OF THE ARMY
do you have to reset modem to accept new mac address
K
kri
Guest
first of all thx a lot for your quick responses
hmm i didn't enter any mac adresses - wouldn't even know where i'd find it ;( ... is the mac adress in bios the same one that is shown under ipconfig and in the configuration of the network controller in win (think it's called "network adress" there)? if so, an adress IS displayed (with ipconfig, not in the card's settings)
btw, i didn't enter any mac adress for the 3Com card eitehr.
and how should i reset my modem ??
thx again
would be nice if anyone could help
kri
