Tech-Support Never seen a motherboard worse than MSI B850 Edge Ti
Troubleshooting
storm_999_
I literally tried every single brand in the market prior to MSI. While expecting it to be final destination,
I just realized none of them were as bad as the MSI !
First of all there is not even a detailed picture of your product on the internet omg. what a pity.
and today, I wanted to play a game which forced me to update the bios for 'anti cheat stuff'
then motherboard literally just died. I wanted to get into bios update screen in the bios. right after i pressed mflash menu whatever its name, pc has frozen, then I went for bios flash button thing and it goes infinite loop.
I dont want to send the motherboard to your potentially crappy service which will make it worse for sure as all services do!, god damn!
Well, do you want some actual help from us after this rant? Then it would be good if you listed your board model at the very least (if not all components including PSU), and what you have tried so far, for example a simple Clear CMOS is a good thing to try. Then we can see what else there is to try.
I'm going to guess user error.
I agree, but with this caveat: the M-Flash failure was his fault. MSI bears some responsibility for the BIOS Flashback failure.
For M-Flash to work, the directions must be followed exactly. M-Flash is otherwise the best way to update the BIOS and has been done probably tens of thousands of times by us users without fail.
There is no excuse for MSI to allow BIOS Flashback to "brick" one of their motherboards.
There is no excuse for MSI to NOT supply a USB drive that is guaranteed to work for BIOS Flashback on their motherboards with this feature.
Or MSI should write code that is more robust, less strict in what USB drives work with BIOS Flashback so that if Windows can read the drive, so can MSI.
I've used all top dogs' motherboards; if you think MSI is bad, wait till you try Gigabyte! MSI motherboards are far better than Gigabyte's, and I have used Gigabyte mobos more than any other brand.(Due to availability where I live)
My current setup has an MSI motherboard. The MSI motherboards I used are far less than Gigabyte or Asus, but the problems I faced with MSI are far fewer than Gigabyte. At least MSI doesn't market junk as a motherboard.
With Gigabyte motherboards, I have seen broken BIOSes, halted support for a product with no non-beta BIOS at all, buggy software that crashes the PC or just won't work, USB ports that die suddenly, or even don't supply enough power to run a 2.5 external drive! Or a marketed top overclocking motherboard that won't overclock at all.
Between MSI and Gigabyte, I would take MSI without thinking. They work as intended, and the community here is amazing.
Well the fact that, Bios flashback really bricked the motherboard! (Even if you dont want to believe)
I am 33 years old, This is my around 10th computer, I am software engineer and spent my whole life in front of the screen.
Btw i dont ever remember that I claimed Gigabyte is better, once i tried it by replacing the 2013 made Asus. I can't say I faced issue with it though. But overall quality of gigabyte absouletely seemed to be worse than Asus.
My nightmare with Asus was mainly the local service. But also the bios issue i face in 2013 was, bios clock was freezing/resetting or something like that.
I wrote "brick" in quotations because your motherboard, and a fine one it is, is still 100% fixable. Since Click BIOS and M-Flash are inaccessible right now, your two options are BIOS Flashback and manually programming the BIOS chip with an EEPROM writer.
For BIOS Flashback, follow directions exactly and try different USB drives. Smaller capacity and older USB drives are favored.
CH341A is the hardware that can erase your present BIOS chip and write a BIOS file to it.
