aiam156f02df
- Sep 12, 2024
CPU : I5-13600K
Mobo : MSI MAG B760 GAMING WIFI
RAM : 32GB (2x16) DDR5 6000 MHz CL30
I built my first PC and everything worked fine for a few hours until I changed my monitor settings to disable Smart HDR. The moment I clicked on "off" I lost signal and the monitor suddenly didn't recognize my PC. The DP cable works.
I rebooted the computer but it kept rebooting every 15 sec. It starts with the CPU on red for about 1 sec and turns off, then goes to orange on the DRAM for about 1 sec and turns off, then to white on VGA for about 3 sec and turns off, then no light for about 10 sec and it reboots. The fans are turning but the RGB lights do not (there's a green dot for half a second but that's it).
When I spam the Delete key, my PC doesn't reboot and it seems I get access to the BIOS, but since I have no display I can't see what I'm doing.
When I boot without RAM I have the DRAM led staying on and the PC doesn't reboot. No beeping sound at all. When I put one RAM stick on the first slot closest to the CPU the PC doesn't boot at all, as if the PSU is dead. Still no display in all these instances.
I have tried
- Removing the CMOS battery and wait for 30 min
- Shorting the pins
- Booting with 1 RAM stick
- Booting without RAM
- Booting without GPU
- Plugging CPU_POWER2
- Checking for loose cables and RAM
- Plugging the GPU on a different PCI5 slot
Note that I did change the RAM frequency and went from 4200 to 6000 MHz. This was done a few hours prior to my problem and I did reboot the PC to confirm the BIOS change with no issue.
Any idea? I'm getting desperate...
I have tried
- Shorting the pins
