Specs:
MSI Big Bang-XPower LGA 1366 X58
i7-930 2.8GHz
Cooler master Intel Core i7 compatible V8 RR-UV8-XBU1-GP
Corsair Dominator-GT 12GB (6 x 2GB) DDR3 1866
XION Power Real XON-1100P14HE 1100W ATX 12v v2.2 / EPS 12V v2.91 / SSI 2.92 SLI Ready Power Supply
Crucial RealSSD C300 128GB Sata III
x2 EVGA 01G-P3-1465-AR GeFroce GTX 465 (Fermi) 1GB 256-bit GDDR5
(If I'm missing anything necessary please let me know, I think I got all of the important components.)
I put the entire build together and the first time I powered the system on it turned on and ran fine but had no POST (was powered on for about twenty seconds, no trouble). I was able to power it off holding the power button for 3 seconds. On a second and any subsequent tries to power the machine on it would run for 1-3 seconds and then immediately power off. I've combed the wiring several times for errors in putting it together but am confidant that is not the problem - from what I've read as long as the 8-pin connector (#2, not #3) and 24-pin connector are on I should at least be able to have continous power. Both of these are plugged in, the 8-pin using two four-pin connections. The #3 8-pin power connectors are not connected.
I've also tried using a separate power supply. I did *not* remove any components when I swapped power supplies, however I did unplug everything. I then plugged in only the 8-pin and 24-pin power connections and received the same problem.
When I get home I'm going to try remove everything and try the board+PSU+processor+1 stick of ram at a time on my tabletop, and I'll also try this configuration with the second power supply.
I was just wondering if there were any other possible solutions or cuplrits that I may have missed? I know resetting the CMOS is a common suggestion but I'm unsure how to do this - I'm a novice builder at best. If all of the above fails I'll try reseating the processor and reapplying the thermal paste/fan, but I'm relatively confidant I did both of those things correctly (I used a smal X of thermal paste on the processor, and I lined it up with the arrow pointing to the arrow on the mobo. If I end up reseating the processor I'll try the grain of rice method for the paste.)
All components are new fresh out of the box. Error code before the system shuts up is 68.
Thanks for any help!
i7-930 2.8GHz
