Some guys say this on amazon lol:
"If you run into system instability issues and constant BSOD's go into bios and turn on the game boost or basic auto overclocking and the issue will be resolved. For whatever reason the board seems to undervolt the CPU when running stock out of the box causing major stability issues. I chased down the issue for 3 weeks and was ready to RMA it before coming across this fix on the 13th page of a random forum and haven't had an issue since."
"Bought this board to replace a dead Gigabyte X570 board. Needed something immediately to get my system back up. Good thing as the Gigabyte RMA process is now going on to 8-weeks with no replacement being sent. Anyways, installed the board and the system was back up and running. I was actually amazed that I didn't have to re-install windows it just added the drivers and booted. However after using the board for a couple of weeks, it was very unstable, lots of crashes and system hangs. Decided to system format and do a fresh install of Windows. Discovered the default config with this board was very unstable, constant BSOD's. DMP file analysis showed over 12 recurring issues appearing. Just could not pin it down. Although the Gigabyte board died, the system was stable for 11 months with no issues, the only component change was the motherboard. First thing I did was remove Dragon Center, that software is horrible and that alone drastically improved reliability. However, still would get constant BSOD's mostly when the system was idle. After reading some forums decided to turn Game Boost ON and X-AMP ON in the bios. Not interested in overclocking so never bothered with those settings. However, since the change the system is finally stable. Been 1 week and not one BSOD so far. I think the board is overly aggressive trying to save power when not overclocking. Perhaps it's undervolting too aggressively? Not really sure but if the board is unstable, try turning on the simple overclocking options in the bios."
Tried and enabled game mode and xmp on cbp and pbo. Now it is running at 4.18 Ghz 1.400 Core Voltage (locked) and x42.0 multiplier locked, no random bsod so far in 3 hours, i don't know if is good for the processor lifetime have enable game mode 24/7 lol. What happens? Is my Ryzen 5 3600 bad? Or did I run too unlucky and get 2 bad x570 tomahawks? I really don't know, I need my PC to work, I am an architecture student my free time is mostly limited, and now I am starting to despair
