NIGHTBLADE MI3 no (Wake on LAN function)
Offa
Hi to all ..
I'm trying to turn on my desktop with Alexa using (Wol app ) skill only allows to turn on PC compatible with the technology "wake on lan".
when I tried to setup the Wake on LAN function on my NIGHTBLADE MI3 bios , there is no option of Resume By PCI or PCI-E Device” in the Wake Up Event Setup.
i have already install the last bios version and did every thing and I've come to the conclusion that computer's BIOS not support integrated LAN controller.
My question is :
is there any ways to active option of Resume By PCI or PCI-E Device” in the Wake Up Event Setup
Or
I have to upgrade the PCIe LAN card. and which one compatible with NIGHTBLADE MI3 motherboard ?
this is my PC page https://www.msi.com/Desktop/Nightblade-MI3/Specification
waiting for help please ...
Offa
Hi FlyingMog,,
First of all, I would like to thank you for your help ...
I tried your suggestion and
-disable EuP 2013
- Unclick "Turn On fast setup"
it did not work
in power management this is what i have not like the guide in the detail refer to link above
Not like the picture
any help please
FlyingMog
PRIVATE FIRST CLASS
I do not know if the Alexa using (Wol app) be in compatibility NIGHTBLADE MI3. I would suggest to use such MagicPacket APP to verify the WOL feature first from the Sleep or Hibernate. If it works, please refer to below link and try the suggestion to see if can help you. PS: The Wifi module in NIGHTBLADE MI3 is not supported WOL feature.
Offa
Hi FlyingMog,,
Not working too .. NIGHTBLADE MI3 is not supported WOL feature ,, i think i have to upgrade the PCIe LAN card ,, But how??
FlyingMog
PRIVATE FIRST CLASS
NIGHTBLADE MI3(MS-B919) can support WOL feature as attached settings by Magic Packet APP (Sleep/Hibernate or shut down), and you can check it again without using Alexa (WOL APP).
