M
Morpheus
Guest
My config:
MSI K7T turbo (latest bios)
Via chipset (latest drivers also tried ide miniport driver)
Athlon XP 1700+
prim master 40GB IBM 60gxp
prim slave 6,4GB WD
sec master dvd/cdrom Aopen 16x (UDMA4)
sec slave cdburner Aopen crw3248 (UDMA2)
I've got a strange problem. My cdrom are not able to reach UDMA. The bios shows the right UDMA-mode. But in windows XP they will only get to Multiword DMA 2. When I change my config I found out that my cdroms will get UDMA on primary IDE and but not on secondary IDE. For experimental reasons I even changed my primary and secondary so my cdrom are on prim and my hd on sec. Everything works, everything is UDMA but I heard that it is not advisable to put you boot hd on secondary IDE. So I changed it back
I also tried to change the registry (according to an article I found on this forum) to manually set it to UDMA but it changes to multiword dma 2 again by boot up.
This problem also occurs with win2k. Any one got a suggestion!?!?
Thanx Bob
Athlon XP 1700+
prim slave 6,4GB WD
Thanx Bob
