No Wifi networks found and bluetooth is gone
No Wifi networks found and bluetooth is gone. after updating thru windows booster and update in microsoft my wifi cannot scan networks around me it says no wifi networks found even tho i have my network. also the bluetooth is gone
Which driver for wifi and bt did you have in use?
What system changes have you made before having the issue?
Did you try to install Killer Wireless LAN Driver(23.10.0.8) and Intel BlueTooth Driver(23.0.1.1)?
If it is not working after installing the drivers, you should check if the devices are detected under device manager.
I am wondering if it is a hardware issue. If so, try to perform an EC reset.
