Noice Issue
Maxit
Since i recieved my PC (Infinite x2 13f 4000serie) i got a Noice issue. I seem to have random vibration sounds. I don't exactling know from where, its hard to find out. But i think its at the top. Becaus with my hand i feel the vibration on the top front grill(red arrow at the picture), and not at the back. It are short bursts of metal-like vibrations. It seems random and there does not seem to get worse if the fans going higher in RPM.
I am going to try to tighten or loosen the screws, if necessary using a "spacer"(language?).
No my question are there similar problems with these cases/fans/AIO and can the problem be the AIO/radiator itself? Its not a crackling/bubble/scrathing sound yet.
Since i recieved my PC (Infinite x2) i got a Noice issue. I seem to have random vibration sounds. I don't exactling know from where, its hard to find out. But i think its at the top. Becaus with my hand i feel the vibration on the top front grill(red errow at the picture), and not at the back. It are short bursts of metal-like vibrations. It seems random and there does not seem to get worse if the fans going higher in RPM.
that spot lines up perfectly with the AIO Water Cooler Pump
The weird thing is that "square"is not there. On all advertisment on MSI, and youtube reviews its there. But absent from my model...
do i have a diffrent model, somehow.
if its a MSI Branded Water Cooler it has the Square as the pump has to be in the Radiator itself as Acertech have a patent on the Pump in the CPU Block and are Patent Trolls about it.
have a more careful Look as if its in the way you have drawn its where they always put the pump
Its not there, Its A MSI built PC, The AIO has the MSI logo on the CPU side. But that Square piece is not there. How can it function the same if its a diffrent cooler? The pc is msi mpg infinite x2 13fnui-033mys. The only thing i can come up with, is maybe the the parts are diffrent for specific regions? But all X2 13F i have seen on photo's, advertisements, Videos and reviews all have that square.
I though i fixed it. I looseb the screws of the fans on the radiator and placed some soft material between case & radiator. the sound was gone for most of the time and if i hear it the noice was reduced with 90%. However its a very irritating noice at any level. But during a certain game i hear it again. With some tasksk/games i hear it more than other but it doesn't have to be a necessarily more demanding game.
Its a bad video. turn up the volume. Don't mind the bumps and crackling on the back ground. the "zoom/vibration" starts at 6-9 "loudest. 13secs+
