Nvidia GTX 660 Twin Frozr fans not spinning
Status
Not open for further replies.
jhonel83
CORPORAL
Lately I had noticed my graphics card are making a very loud noise when gaming. I opened the case and took a look -the fans are not spinning until the gpu reaches a critical temperature, like 90 degrees Celsius, and then it does so at max speed for a short burst, then stops again. As the heat builds up again it does another short burst, and so on.
   The fans spin fine for 1-2 seconds when I start the pc (when I press the power button) then stop. Can't control them with Afterburner. Manual makes them work, but only when I set them to maximum speed. Setting them to under 90% speed seems to have no effect (dough at pc start, they spin quietly, at a normal 30%).
   Nvidia inspector shows correctly the fans are not spinning, as you see in the screenshot. Afterburner is confused and still shows them at 30%, 40% and so on in the graph, like nothing has happened.
   I think this issue is quite recent, I don't remember it happening when I bought the card. I didn't do anything special to it, I cleaned it just once this summer, using a small brush and blowing into it. Even If I did manage to jam dust into one of the fans so it doesn't spin, that wouldn't explain how come neither of them are working properly. I also did a motherboard bios upgrade for my motherboard from this site, but that was fine, no issues caused. I switched back to factory bios now, just to make sure.
   Note I checked my power source is not faulty by plugging the card into another pc. It displays the same issue as well. Yes, I also made sure the pci-e cable is connected fine.
   I've seen plenty of topics with some bugs regarding these cards that makes them behave like so. In all the threads, the solution was an update to the gpu bios. I don't trust external sources for this -can I have a solution for my card model, please?
Name: Nvidia GTX 660 Twin Frozr
S/N: 602-V287-050B1305065285
Part number: N660 TF 2GD5/OC
Current gpu BIOS: Version 80.6.28.0.39
Status
