OCUBA - Overclocking Utilities and Benchmarking Applications
Status
Not open for further replies.
Aaron
Active member
GENERAL
Always remember the risks of overclocking. If you damage something it's no one's fault, but yours. Overclocking components beyond stock specifications creates more heat; BE SURE to make it absolutely certain you have sufficient cooling to address the speeds your running at.
MSI (Micro-star International), this forum, or any of it's members will NOT be liable if you cause any damage.
Neither is any support provided for these programs.
"Don't cry if you blow stuff up."
ALWAYS remember the risks!
:oc:
Layout:
Click app title to go to info/homepage.
Download button to download app.
<hr>
System Tools:
ClockGen
ClockGen is an program dedicated to overclocking. Its main purpose is to change the system clocks on the fly : FSB (Front Side Bus) and GSB (Graphic Side Bus). ClockGen also provides some functions that allow you to improve and monitor your overclock.
Download
CPU-Z
CPU-Z is a freeware that gathers information on some of the main devices of your system. On the right side select whatever file you wish to download
Download
Intel Burn Test
Intel Burn Test is a very demanding stress test on the cpu and memory. If your computer completes a maximum burn test, you can be fairly confident that it is stable.
GPU-Z
CPU-Z for your GPU!
Download
NVIDIA System Tools
nTune for your whole NVIDIA-based machine.
Download
Real Temp
Real Temp is designed to read the 45nm "Penryn" (Yorkfield/Wolfdale) Core 2 processors correctly. Look at the homepage for a setup guide and tutorial.
Download
CoreTemp
Core Temp is a compact, no fuss, small footprint program to monitor CPU temperature.
The uniqueness of it is that it shows the temperature of each individual core in a each processor in your system! You can see in real time how the CPU temperature varies when you load your CPU.
Download
Speed Fan
If you need a tool that can change your computer's fan speeds, read the temperatures of your motherboard and your hard disk, read voltages and fan speeds and check the status of your hard disk using S.M.A.R.T. or SCSI attributes, then you came to the right place. SpeedFan is the software to go. It is fully configurable and you can create custom events to handle every situation in an automated way. SpeedFan works under Windows 9x, ME, NT, 2000, 2003, XP and Vista. SpeedFan works fine on Vista 64 bit too. The relevant driver is fully digitally signed.
Download
EVEREST Ultimate Edition
EVEREST Ultimate Edition is an industry leading system diagnostics and benchmarking solution for enthusiasts PC users, based on the award-winning EVEREST Technology. During system optimizations and tweaking it provides essential system and overclock information, advanced hardware monitoring and diagnostics capabilities to check the effects of the applied settings. CPU, FPU and memory benchmarks are available to measure the actual system performance and compare it to previous states or other systems. Furthermore, complete software, operating system and security information makes EVEREST Ultimate Edition a comprehensive system diagnostics tool that offers a total of 100 pages of information about your PC.
Download
CoreMeter
CoreTemp... With a graph!
Download
HWMonitor
HWMonitor is a hardware monitoring program that reads PC systems main health sensors : voltages, temperatures, fans speed.
Download
NextSensor
No description yet.
Download
AMD overclocking:
AMD OverDrive
AMD's overclocking tool for 790FX and Phenom. Allows core frequencies to be altered independantly.
Download
A64tweaker
Memory timings tweaker for Athlon 64 users.
Download
A64MemFreq
Memory divider assistant.
Download
Central Brain Identifier
Program similar to CPU-Z.
Download
A64Info
Another memory controller tool.
Download (v.05)
Download (v.062 BETA)
Intel overclocking:
MemSet
MemSet is a memory tweaker for:
-Intel 815 845 855 865 875 915 925 945 946 955 965 & 975.
-AMD A64 ddr&ddr2.
-nVidia NForce2, NForce 650i & 680i.
-VIA KT266/333/400/600.
Download
SysTool
Gives a read out of the current northbridge strap.
Download
SiSoftSandra XI Lite
Gives a read out of the current northbridge clock.
Download
NBCCCalc
Simple tool to calculate the northbridge clock at different settings.
Download
Thaiphoon Burner
Tool for reflashing and altering SPD values.
Download
VGA Card Overclocking:
>>How to use MSI Afterburner<<
RivaTuner
RivaTuner is a complete powerful tweaking environment, providing you everything you may need to tune NVIDIA GPU based display adapters. The widest driver-level Direct3D / OpenGL and system tuning options, flexible profiling system allowing to make custom settings on per-application basis, both driver-level and low-level hardware access modes, unique diagnostic and realtime hardware monitoring features and exclusive power user oriented tools like built-in registry editor and patch script engine make RivaTuner's feature set absolutely unmatched.
RivaTuner supports all NVIDIA display adapters starting from Riva TNT family up to the latest GeForce 7 series and widest range of NVIDIA drivers starting from the oldest Detonator 2.08 up to the newest ForceWare drivers family.
Download
ATI Tool
ATITool is an overclocking utility designed for ATI and nVidia video cards. Design target is to write a light-weight application for the enthusiast - so no questionable registry tweaks. Sorry.
Download
ATI Tray Tools
ATI Tray Tools is a Full Featured Radeon Tweaker that can be found in the windows tray which then allows instant access to options and settings.
Download
nVidia Timmings
No description yet.
Download
AMD GPU Tool
This will overclock your AMD VGA card.
Download
NiBiTor v4.0
NVIDIA BIOS Editor
Download
Video Memory Stess Test
Stresses VGA card memory.
Download
nVHardPage SE
No description yet.
Download
nVidia Tray Tools
No description yet.
Download
Stability Testing:
Prime95
System stressing utility.
Tips:
Password is 9876. (Allows priority changing)
To run 2 instances of Prime95: For e.g open Run. Type "C:\Program Files\Prime95\Prime95.exe" -A1 (speech marks are required)
Download
BETA Prime95 that automatically sets required threads. (Handy for quad core users!) Download
MemTest86
Memory failure detection tool.
Download (Bootable ISO)
Download (.exe for USB Key/Drive/Stick)
IntelBurnTest
Simple command line based program to simplify the use of Intel's Linpack application.
Download
SuperPI
CPU stressing utility.
Download
Milliseconds Mod
Intel Thermal Analysis Tool
Intel's TAT can utilize an Intel CPU beyond any other app.
Download
SP2004 Orthos Edition
Dual core and memory stress testing.
Download
SuperPrime
New benchmark based on Prime95 code.
Download
wPrime
wPrime is a benchmarking application designed to use a highly multithreaded approach to calculating the square-roots of large amounts of numbers.
Download
Other
CrystalCPUID
Amazing tool. Many, many options to use and choose from. (Intel & AMD)
Download
RMClock
RightMark CPU Clock Utility (RMClock) is a small GUI application designed for real-time CPU frequency, throttling and load level monitoring and on-the-fly adjustment of the CPU performance level on supported CPU models via processor's power management model-specific registers (MSRs). In automatic management mode it continuously monitors the CPU usage level and dynamically adjusts the CPU frequency, throttle and/or voltage level as needed, realizing the "Performance on Demand" concept.
Download (.RAR)
MemTest for Windows
Same old MemTest app.
Download
OCCT Perestro?ka
Download
S&M
No description yet.
Download
DPC Latency Checker
Checks latency, show safe, moderate and dangerous values. Check page for more detail.
Download
Ah yes... We can't forget to see how much of a change your overclock did now can we...
BENCHMARKING! ;D
Crysis Benchmark Tool
The tool provides a robust front-end to benchmark Crysis. It provides the ability to queue up many runs and will provide detailed results for each test as well as an overall summary with accurate averages. The first and foremost goals were simplicity and reliability in the tool and in the benchmark scores. Works with retail and demo.
Download
FRAPS
Video and CPU benchmarking Utility
Download
3DMark06
The legendary benchmark from FutureMark.
Download (Select mirror)
Nuclearus Multi-Core 2.0
The program Nuclearus Multi Core wrote to test speed of computer system (CPU-CHIP-RAM) and comparison with other computer system. You can use it to tuning, testing and benchmarking your system.
Download
Sciencemark 2.0 FINAL
No description yet.
Download
Toast
No description yet.
Lightsmark
A new 3D benchmark focusing on lighting effects and performance, dubbed Lightsmark, has been released for free by Czech software author Stepan Hrbek. This OpenGL 2.0 optimized test runs a flyby scene featuring realtime global illumination, color bleeding, penumbra shadows and displays the average FPS as an end result.
Download
Smart FPS
SmartFPS.com is a free software to benchmark latest videocards and processors by real world games like Crysis, Call Of Duty 2, Battlefield 2, Serious Sam 2, Call Of Juarez (full version), Quake 4, Prey and The Chronicles of Rid:censored:: EFBB.
Download
Cinebench R10
MAXON CINEBENCH runs several tests on your computer to measure the performance of the main processor and the graphics card under real world circumstances..
Download
Rightmark Memory Analyzer
Tip is in the name.
Download
ShaderMark
No description yet.
Download
AquaMark 3
No description yet.
Download
3DMark05
Another Futuremark benchmark.
Download
OpenGL Fur Rendering Benchmark
This benchmark requires a NVIDIA GeForce 5/6/7/8 (and higher) or an AMD/ATI Radeon 9600 (and higher) graphics card with the latest graphics drivers.
The startup interface allows you to tweak the benchmark features such as:
    * Benchmark mode or stability test mode (for overclockers)
    * Fullscreen or windowed for each type of run mode
    * Window size selection (standard or custom)
    * MSAA samples selection
    * Benchmarking parameters: time based or frames based
Download
MSI 990FXA GD80: versions of Control Center and Click Bios II that allow oc
>>Control Center<<
>>Click Bios II<<
Post a submition, I'll gladly add it to the list.
UPDATE: *Fix +Addition -Removal /Modification
+ Added new stability tester "SuperPrime v0.9.9".
<hr>
SuperPrime
"A benchmark to reckon with!"
Download
http://www.cpuid.com/cpuz.php
    *  Intel Atom Z500/Z510/Z520/Z530/Z540 processors.
    * Intel Core 2 Duo E7x00 processor.
    * AMD 45 nm Phenom (Dened & Shanghai) processors.
    * Intel P45 chipset.
Exe file properties
    * MD5 (cpuz.exe 1.45) : DD4E540C04297CF93DC721166C13446E
Download
Core Temp 0.99 Final {18.05.2008}
What's new?:
- Fix: Incorrect recognition of 45nm Mobile Intel CPUs.
- Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1).
- Fix: CPU load would sometimes display -1% load.
- Fix: AMD K8 would sometimes spike to 206C, the false reading is now ignored.
- Fix: AMD K8 sometimes constantly reads -49C.
- Fix: Core Temp does not show up automatically on G15 LCD with 2.02 driver.
- Fix: Shared memory structure was not properly filled on multiprocessor systems.
- Fix: System tray setting "Show highest temperature of each CPU" only displays one temperature reading in a multi CPU system.
- Fix: Certain problems with font resizing should now be fixed.
- Fix: G15 LCD would not update after using soft buttons.
- Fix: On temperature display mode change, high and low records were not reset.
- Fix: Changing the reading interval in settings did not actually update, restart of Core Temp was needed to apply the change.
- Fix: Incorrect VID detection on 45nm desktop Intel parts.
- Add: Shared memory - developers now have access to Core Temp data.
- Add: Register dump to text file function.
- Add: Preliminary Atom (Silverthorne) support - Untested.
- Add: Support for Intel Core 2 Duo E7000 45nm series.
- Add: Option to show a single icon instead of temperature in the system tray.
- Add: Custom font and size for G15 LCD screen or simply use the built in compact font and layout. (via Settings.ini)
- Change: Improved detection of L2 cache on Intel chips for more accurate recognition.
- Change: Rewritten temperature calculation to fix problems with shared memory.
- Change: Default G15 LCD text layout and font changed.
- Change: Doesn't create a log file containing session start and end times if logging is disabled.
- Change: Settings.ini file is automatically created with default settings in case one doesn't already exist.
Download: http://www.alcpu.com/CoreTemp/CoreTemp.zip
What Is MAXON CINEBENCH?
CINEBENCH is a real-world test suite that assesses your computer's performace capabilities. MAXON CINEBENCH is based on MAXON's award-winning animation software, CINEMA 4D, which is used extensively by studios and production houses worldwide for 3D content creation. MAXON software has been used in blockbuster movies such as Spider-Man, Star Wars, The Chronicles of Narnia and many more.
MAXON CINEBENCH runs several tests on your computer to measure the performance of the main processor and the graphics card under real world circumstances. The benchmark application makes use of up to 16 CPUs or CPU cores and is available for Windows (32-bit and 64-Bit) and Macintosh (PPC and Intel-based).
The resulting values among different operating systems are 100% comparable and therefore very useful with regard to purchasing decision-making. It can also be used as a marketing tool for hardware vendors or simply to compare hardware among colleagues or friends.
Details and download: http://www.maxon.net/pages/download/cinebench_e.html
+ Added Real Temp v2.60 (Thanks to russellmrgn)
+ Added Cinebench R10 (Thanks to BOSSKILLER)
/ Updated AMD GPU Clock Tool to v0.9.8. (Thanks to AaronYuri  :-)) )
+ IntelBurnTest:
IntelBurnTest
Download
<hr>
I found this application great, personally! Linpack is reported to be better than Prime95's tests.
CPUCalc 1.9.2
CPUCalc is an overclocking-calculator able to overclocking with many Intel and AMD processors.
You just need to set your wished clock and it calculates all other settings, for example. It automatically sets the correct CPU-RAM-ratio and Referenceclock:HTT-Ratio.
It?s also able to calculate the new TDP with the overclocked settings.
imageview.php
Download:
http://downloads.guru3d.com/CPUCalc-1.9.2-download-2017.html
GPU-Z 0.2.7
GPU-Z 0.2.7 is out and it supports catalyst 8.7 beta & latest forceware drivers.
Here is the list of changes :
    *  Added display for GPU release date.
    *  Added display for transistor count
    *  Added mouseover readings for sensors graph
    *  Correctly named the three on-die sensors of RV770 and RV730
    *  Added support for voltage regulator monitoring on HD 4870 and HD 4870 X2
    *  RV770 GPU on HD 4870 X2 now called R700
    *  Added support for reading HD 4870 X2 3D clocks
    *  Added display of CrossFire Sideport status on HD 4870 X2
    *  Added more RV730 device IDs
    *  Added support for GeForce 9800 GT, 9800M GT, 9600M GT, 9700M GS/GT, 9500M G
    *  Added detection for RS780D
    *  Fixed incorrectly read ATI OD5 clocks
    *  Fix for memory clock reading on RV730
    *  Fixed ROM reading on RV730
    *  Fixed crash when no supported card detected
    *  Sensor graph width adjusted when scrollbars visible
Download:
http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
PhysX FluidMark v1.0.0
  PhysX FluidMark requires NVDIA PhysX drivers 8.08.01 or higher and the CUDA DLL (this DLL has to be copied in the benchmark folder if your Forceware drivers are < 177.79 or if you don't have a GeForce (Radeon, etc.)).
PhysX FluidMark is a physics benchmark based on NVIDIA PhysX engine. This benchmark performs a fluid simulation by imitating the renderering of lava. Real physics parameters such as viscosity are used. SPH (Smoothed Particle Hydrodynamics) algorithm is enabled to increase the realism of the simulation.
PhysX FluidMark can run in pure software mode (all calculations are done on the CPU), or in hardware mode. Hardware mode includes 2 kinds of hardware:
    * Ageia PhysX PPU
    * GeForce PhysX - GeForce 8/9/GTX200 graphics cards only
This benchmark exploits OpenGL for graphic acceleration and requires an OpenGL 2.0 compliant graphics card: NVIDIA GeForce 5/6/7/8/9/GTX200 (and higher), AMD/ATI Radeon 9600+, 1k/2k/3k/4k (and higher) or a S3 Graphics Chrome 400 series with the latest graphics drivers.
Download:
http://www.ozone3d.net/benchmarks/physx-fluidmark/
Score database:
http://www.ozone3d.net/benchmarks/physx_fluidmark_scores.php
just incase someone not posted this already
MotherBoard Monitor 5 with Intel Core CPU support including C2D/C2Q
http://www.thetechrepository.com/showthread.php?p=138
yeah the old school classic and father of all good hw monitoring programs :) is still alive and kicking
Download and details, RivaTuner 2.24b (MSI MOA Edition)
http://downloads.guru3d.com/RivaTuner-v2.24b-download-163.html
That Calc util is old, and not updated..
their website forum doesn't work..
just a heads up..
Svet said:
CPUCalc 1.9.2
imageview.php
Download:
GPU-Z 0.2.7
Download:
    * Ageia PhysX PPU
Download:
Score database:
The MSI 990FXA GD80 can not be overclocked with the latest versions of Control Center and Click Bios II.  I have earlier versions that do allow overclocking.  Is it allowed for them to be posted here?
Ok, here are links to my Dropbox.  They will be removed later to prevent it from being closed.
https://www.dropbox.com/sh/gpalg0tpyyfcivy/AAA_vvHgq7MUkdcXPH3Nh5rWa/CLICKBIOSII.7z?dl=0
https://www.dropbox.com/sh/gpalg0tpyyfcivy/AACw8NaNIQvgSLXdd-qvznioa/ControlCenterII.7z?dl=0
I just found out that you posted links to my Dropbox for CC and CBII.  Is there any way for you to download them and post them in the 1st post so when my Dropbox gets closed they will still be available?
Status
