Optix Mag274 OSD Settings Not Visible
northrw150a02cf
If I click on the "gear" icon for settings in the Gaming OSD app, clicking on something such as "DP" does not seem to stick. There is no way to see what the settings are after the fact. I've tried turning down the brightness, etc., to no avail. Is this just a bug or am I missing something? I'm running at 144 if that has any impact. I downloaded and installed latest version of Gaming OSD.
FlyingMog
PRIVATE FIRST CLASS
Hi, Do you use HDMI cable on 1920x1080@144Hz? If yes, it will be no function when you click "gear" icon (System Setting), click DP item. It is because you do not connect DP input source. Please check it first or if you have other items unavailable, recommend you download user manual as below and refer to Gaming OSD settings in manual. https://download.msi.com/archive/mnu_exe/monitor/Optix_MAG274_274Rv1.0_English.pdf
