GaiusEmil
GaiusEmil
- Nov 15, 2021
This monitor is absolutely the BEST 27" gaming monitor I have used
. It doesn't lose any colors when viewed from different angles. Changed my curved monitor to this.
With Windows 11, auto HDR is easy and simple to use, and games look GORGEOUS in HDR and 2556x1440
I recommend it for everyone looking for WQHD gaming display. All my games got a huge facelift with this
-Monitor has it's own Gaming OSD program which you can use from your Windows
-Good refresh modes: 48 to 165Hz
-Rapid IPS panel!!!
- G-sync Compatible
-Good selection of connections
1x Display Port (1.2a)
2x HDMI (2.0b)
1x Type C (DP alt.)
-Own usb HUB :
2x USB 2.0 Type A
1x USB 2.0 Type B
-Has subtle RGB on the back of the monitor
-The monitor stand is extremely sturdy and contains a passthrough for the cables
Link to website https://www.msi.com/Monitor/Optix-MAG274QRF-QD
-Rapid IPS panel!!!
- G-sync Compatible
2x HDMI (2.0b)
1x Type C (DP alt.)
-Own usb HUB :
2x USB 2.0 Type A
1x USB 2.0 Type B
